08-31-2015, 15:21 | #1 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 303848 Status: Offline Thanks Meter: 14 | LG d852 lollipop unlock success Found 1 device(s) Device name: LG-D852 Firmware version: Android release: 5.0.1 Platform: msm8974 Root status: OK! Checking phone at COM54 No answer from phone Elapsed: 7 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Android Lollipop detected Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 7 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Checking phone at COM54 No answer from phone Elapsed: 4 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check adb server status... OK Device not found! Enable USB debugging: 1. Menu -> General -> About phone -> Common -> Software Information -> 7 times click in Build Number. 2. Menu -> General -> Developer options -> Enable USB debugging. Elapsed: 2 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check adb server status... OK Found 1 device(s) Device name: LG-D852 Firmware version: Android release: 5.0.1 Platform: msm8974 Root status: OK! Checking phone at COM54 No answer from phone Elapsed: 7 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check adb server status... OK Device not found! Enable USB debugging: 1. Menu -> General -> About phone -> Common -> Software Information -> 7 times click in Build Number. 2. Menu -> General -> Developer options -> Enable USB debugging. Elapsed: 2 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check adb server status... OK Found 1 device(s) Device name: LG-D852 Firmware version: Android release: 5.0.1 Platform: msm8974 Root status: OK! Checking phone at COM54 No answer from phone Elapsed: 7 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Android Lollipop detected Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 7 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Android Lollipop detected Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 7 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Android Lollipop detected Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 7 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check adb server status... OK Found 1 device(s) Device name: LG-D852 Firmware version: Android release: 5.0.1 Platform: msm8974 Root status: OK! Checking phone at COM56 No answer from phone Elapsed: 7 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check adb server status... OK Found 1 device(s) Device name: LG-D852 Firmware version: Android release: 5.0.1 Platform: msm8974 Root status: OK! Checking phone at COM54 No answer from phone Elapsed: 8 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check adb server status... OK Device not found! Enable USB debugging: 1. Menu -> General -> About phone -> Common -> Software Information -> 7 times click in Build Number. 2. Menu -> General -> Developer options -> Enable USB debugging. Elapsed: 2 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check adb server status... OK Found 1 device(s) Device name: LG-D852 Firmware version: Android release: 5.0.1 Platform: msm8974 Root status: OK! Checking phone at COM54 No answer from phone Elapsed: 60 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check adb server status... OK Found 1 device(s) Device name: LG-D852 Firmware version: Android release: 5.0.1 Platform: msm8974 Root status: OK! Checking phone at COM54 No answer from phone Elapsed: 47 secs. --> (v8.1) Check Android Lollipop... Stage #1 Port already opened! Port already opened! Elapsed: 0 secs. --> (v8.1) Check Android Lollipop... Stage #1 Port already opened! Port already opened! Elapsed: 0 secs. --> (v8.1) Check Android Lollipop... Stage #1 Port already opened! Port already opened! Elapsed: 0 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Android Lollipop detected Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 7 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Android Lollipop detected Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 7 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Android Lollipop detected Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 7 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Checking phone at COM54 No answer from phone Elapsed: 4 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Checking phone at COM56 No answer from phone Elapsed: 19 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Checking phone at COM54 No answer from phone Elapsed: 4 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check adb server status... OK Found 1 device(s) Device name: LG-D852 Firmware version: Android release: 5.0.1 Platform: msm8974 Root status: OK! Checking phone at COM54 No answer from phone Elapsed: 7 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check adb server status... OK Device not found! Enable USB debugging: 1. Menu -> General -> About phone -> Common -> Software Information -> 7 times click in Build Number. 2. Menu -> General -> Developer options -> Enable USB debugging. Elapsed: 4 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check adb server status... OK Found 1 device(s) Device name: LG-D852 Firmware version: Android release: 5.0.1 Platform: msm8974 Root status: OK! Checking phone at COM54 No answer from phone Elapsed: 8 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 12 secs. --> (v8.1) Check adb server status... OK Found 1 device(s) Device name: LG-D852 Firmware version: Android release: 5.0.1 Platform: msm8974 Root status: OK! Checking phone at COM54 No answer from phone Elapsed: 54 secs. --> (v8.1) Check Android Lollipop... Stage #1 Port already opened! Port already opened! Elapsed: 0 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check adb server status... OK Found 1 device(s) Device name: LG-D852 Firmware version: Android release: 5.0.1 Platform: msm8974 Root status: OK! Checking phone at COM54 No answer from phone Elapsed: 7 secs. --> (v8.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check adb server status... OK Found 1 device(s) Device name: LG-D852 Firmware version: Android release: 5.0.1 Platform: msm8974 Root status: OK! Checking phone at COM54 No answer from phone Elapsed: 7 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Checking phone at COM54 No answer from phone Elapsed: 4 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: Build version: xð~ SW Version: IMEI: BAD IMEI BlueTooth Address: 00:00:00:7E:BB:01 Phone Code: SPC: Elapsed: 1 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: D852 Build version: Feb 4 201518:20:29Jan 05 201501:00:00D852 SW Version: MPSS.DI.2.0.1.c1.13-00053-M8974AAAAANPZM-1 IMEI: 35460806271325-2 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: D852 Build version: Feb 4 201518:20:29Jan 05 201501:00:00D852 SW Version: MPSS.DI.2.0.1.c1.13-00053-M8974AAAAANPZM-1 IMEI: 35460806271325-2 BlueTooth Address: 00:00:00:00:00:06 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v8.1) Check adb server status... OK Device not found! Enable USB debugging: 1. Menu -> General -> About phone -> Common -> Software Information -> 7 times click in Build Number. 2. Menu -> General -> Developer options -> Enable USB debugging. Elapsed: 2 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: D852 Build version: Feb 4 201518:20:29Jan 05 201501:00:00D852 SW Version: MPSS.DI.2.0.1.c1.13-00053-M8974AAAAANPZM-1 IMEI: 35460806271325-2 BlueTooth Address: 00:00:00:00:00:06 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: D852 Build version: Feb 4 201518:20:29Jan 05 201501:00:00D852 SW Version: MPSS.DI.2.0.1.c1.13-00053-M8974AAAAANPZM-1 IMEI: 35460806271325-2 BlueTooth Address: 00:00:00:00:00:06 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v8.1) Check adb server status... OK Device not found! Enable USB debugging: 1. Menu -> General -> About phone -> Common -> Software Information -> 7 times click in Build Number. 2. Menu -> General -> Developer options -> Enable USB debugging. Elapsed: 2 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: D852 Build version: Feb 4 201518:20:29Jan 05 201501:00:00D852 SW Version: MPSS.DI.2.0.1.c1.13-00053-M8974AAAAANPZM-1 IMEI: 35460806271325-2 BlueTooth Address: 00:00:00:00:00:06 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: D852 Build version: Feb 4 201518:20:29Jan 05 201501:00:00D852 SW Version: MPSS.DI.2.0.1.c1.13-00053-M8974AAAAANPZM-1 IMEI: 35460806271325-2 BlueTooth Address: 00:00:00:00:00:06 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: D852 Build version: Feb 4 201518:20:29Jan 05 201501:00:00D852 SW Version: MPSS.DI.2.0.1.c1.13-00053-M8974AAAAANPZM-1 IMEI: 35460806271325-2 BlueTooth Address: 00:00:00:00:00:06 Phone Code: SPC: 000000 Elapsed: 0 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: D852 Build version: Feb 4 201518:20:29Jan 05 201501:00:00D852 SW Version: MPSS.DI.2.0.1.c1.13-00053-M8974AAAAANPZM-1 IMEI: 35460806271325-2 BlueTooth Address: 00:00:00:00:00:06 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v8.1) Check adb server status... OK Found 1 device(s) Device name: LG-D852 Firmware version: Android release: 5.0.1 Platform: msm8974 Root status: OK! Checking phone at COM53 Detected ID: 00000FF3 (MSM8974) SW Version: MPSS.DI.2.0.1.c1.13-00053-M8974AAAAANPZM-1 Reading ESN... OK Read SPC... SPC: 000000 Unlock SPC... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Scaning security area by HUMMER algo... Making security area diagram: --------------------++- --------------------++- Backup security zone... Sec zone saved: ..\Backup\D852_354608062713252_31082015_215050.lgs b1 Writing security zone... Reboot phone Phone detected! Reading QCN file... OK Checking phone at COM53 Detected ID: 00000FF3 (MSM8974) SW Version: MPSS.DI.2.0.1.c1.13-00053-M8974AAAAANPZM-1 Unlock SPC... OK Checking paths... OK Restoring EFS Backup... OK Restoring NV Items... OK Restoring NV Item SIM1... OK Restoring NV Item SIM2... OK Restoring Provisioning Item Files... OK Unlock done! Elapsed: 339 secs. --> (v8.1) |
