11-02-2016, 18:27 | #19 (permalink) |
Freak Poster Join Date: Mar 2014 Location: United States
Member: 2146046 Status: Offline Thanks Meter: 62 | If your phone is stuck on LG Logo it could be hardware issue as this is major problem with a lot of LG G4's / G5's. If you reflash phone and it is still stuck on splash screen it could be LG manufacturer defect. This is very common issue with this phone getting stuck in a boot loop on splash screen. LG knows about this but can't do anything about it because their phones suck |
The Following User Says Thank You to GTrader For This Useful Post: |
11-02-2016, 18:40 | #20 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | Quote:
br | |
11-02-2016, 18:59 | #21 (permalink) |
Freak Poster Join Date: Jul 2004 Location: florida
Member: 72939 Status: Offline Thanks Meter: 30 | the problem is the eeprom over heats and loops it at start up. Put it in the freezer for 10 minutes then try to start it. It worked for me on several G4's to recover the info inside. |
The Following User Says Thank You to razor1 For This Useful Post: |
11-03-2016, 14:30 | #22 (permalink) |
Major Poster Join Date: May 2009 Location: Algeria
Member: 1030375 Status: Offline Sonork: aziiiz Thanks Meter: 0 | no success at flashing H810 still the same .. flash done but no success LG 2-3G Tool v9.28 supported models: 1408 Mode: Emergency Model: H810 Read info... Model name: LG-H810 Software verion: H81021y Android verion: 6.0 IMEI: 357905061661244 Elapsed: 4 secs. --> (v9.28) Phone mode is DOWNLOAD Start flashing. Open TOT File : F:\BOX new\LG\H810\LGH810AT-01-V21y-310-410-JUN-20-2016-ARB03+0.tot Model : LG-H810 SwVersion : H81021y BuildTime : Total Files : 28 Model name: LG-H810 Software verion: H81021y Android verion: 6.0 IMEI: 357905061661244 Start direct download mode Write "PrimaryGPT" partition #1 of 28 Write "modem" partition #2 of 28 Write "pmic" partition #3 of 28 Write "sbl1" partition #4 of 28 Write "tz" partition #5 of 28 Write "sdi" partition #6 of 28 Write "hyp" partition #7 of 28 Write "rpm" partition #8 of 28 Write "aboot" partition #9 of 28 Write "sbl1bak" partition #10 of 28 Write "pmicbak" partition #11 of 28 Write "tzbak" partition #12 of 28 Write "hypbak" partition #13 of 28 Write "rpmbak" partition #14 of 28 Write "abootbak" partition #15 of 28 Write "sdibak" partition #16 of 28 Write "apdp" partition #17 of 28 Write "msadp" partition #18 of 28 Write "persist" partition #19 of 28 Write "sec" partition #20 of 28 Write "laf" partition #21 of 28 Write "boot" partition #22 of 28 Write "recovery" partition #23 of 28 Write "raw_resources" partition #24 of 28 Write "raw_resourcesbak" partition #25 of 28 Write "felica" partition #26 of 28 Write "factory" partition #27 of 28 Write "system" partition #28 of 28 Erase "rct" partition Erase "misc" partition Erase "userdata" partition Erase "cache" partition Done. Elapsed: 461 secs. --> (v9.28) ANY OTHER SOLUTION .. like security zone in format *.LGSB1 |
11-03-2016, 14:40 | #23 (permalink) |
Member: 1030375 Status: Offline Sonork: aziiiz Thanks Meter: 0 | i think it's overheating problem .. because after RESET SECURITY ZONE the phone started & after splash screen , the phone started optimizing or installing applications but restarts & kept restarting .. I found the back of the phone heated |
11-03-2016, 16:49 | #25 (permalink) | |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | Quote:
Flash with checked: flash in direct mode erase user data after flash. -- | |
11-05-2016, 13:18 | #26 (permalink) |
Member: 1030375 Status: Offline Sonork: aziiiz Thanks Meter: 0 | Lg g4 h810 firmware phone started but hangs sometimes at logo , other times at installing application .. I tried reset security zone , write LGSB1 security zone from another phone , still the same .. OVER HEATING & HANGS |
05-11-2017, 10:27 | #29 (permalink) | |
No Life Poster Join Date: May 2012 Location: In Your Heart Age: 37
Member: 1759636 Status: Offline Sonork: 100.1591515 Thanks Meter: 785 | Quote:
Download from Here H810 | |
The Following 3 Users Say Thank You to WBGSM For This Useful Post: |
