06-29-2016, 10:16 | #1 (permalink) |
Freak Poster Join Date: Jan 2011 Location: india
Member: 1505730 Status: Offline Sonork: 100.1618029 Thanks Meter: 207 | j200h/dd 2016 june new frp unlock done j200h-dd frp new 2016 june - Download - 4shared Operation: Reset FRP/React/EE Selected model: SM-G920T Software version: 25.8 Searching Samsung USB Flash Interface... detected COM10 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.25.8 |
The Following 9 Users Say Thank You to bikku.gupta For This Useful Post: |
06-29-2016, 14:04 | #2 (permalink) | |
Freak Poster Join Date: Sep 2011 Location: INSIDE DEVICES
Member: 1652212 Status: Offline Thanks Meter: 73 | Quote:
WITH THIS FILE J200H_FRP_g0dsend313 Searching Samsung USB Flash Interface... detected COM86 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.25.8 | |
The Following User Says Thank You to Macie provider For This Useful Post: |
12-08-2016, 11:43 | #8 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Pakistan
Member: 720264 Status: Offline Sonork: 100.1649278 Thanks Meter: 192 | Operation: Reset FRP/React/EE Selected model: SM-G920T Software version: 27.3 Searching Samsung USB Flash interface... COM4 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP... Ok Searching Reactivation lock... not supported Searching EE lock... Ok Erasing EE lock... Ok Reset done Done with Samsung Tool PRO v.27.3 |
The Following User Says Thank You to naveed ali For This Useful Post: |
01-02-2017, 15:31 | #10 (permalink) |
Junior Member Join Date: Sep 2009 Location: okra pakistan skp farooq_sipra
Member: 1113440 Status: Offline Sonork: 100.1612642 Thanks Meter: 4 | 1000000% Operation: Reset FRP/React/EE Selected model: SM-G925T Software version: 27.7 Searching Samsung USB Flash interface... COM21 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... Ok Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.27.7 |
01-21-2017, 19:39 | #13 (permalink) |
Junior Member Join Date: Sep 2011
Member: 1647042 Status: Offline Sonork: chalo Thanks Meter: 2 | ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM13 Modelo seleccionado: SM-J200H Reset FRP/ Reactivation lock operation for SM-J200H will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Could not connect to the server! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J200H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Escribiendo la sección Custom... L a sección Custom ha sido escrita con éxito FRP lock is successfully reseted! Wait 3-4 min then goto "Backup and reset" and make "Factory data reset" Performed by 2.4.7 Software version. |
