08-21-2010, 11:44 | #1 (permalink) |
Insane Poster Join Date: Apr 2003 Location: Uk
Member: 26584 Status: Offline Sonork: 100.1577865 Thanks Meter: 10 | lg GM 360 unlock problem Models count: 75 Current OS : Windows XP Welcome to Sgold3 Module!! Count supported models - 75 Disconnected. Please reconnect phone battery / power source. Loading module , please wait... PMB8877 Module 1.2 started. SW: Ver 2.2.7.3 Connecting to GM360 in UART Mode (COM4 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8877) prebooting... Release power button. Booting... Reading info... BOOT Stage Finished , sending authority... Sending SEC pack... Reading EEPROM... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\GM360_autobackup_21082 010_153458.eep Analising EEPROM... Phone IMEI:352202040188092 Unlock codes: NCK[0]: 2547349373628151 (LOCKED) Finished in 4 seconds Unlocking... Sending SEC pack... Reading ... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\GM360_autobackup_21082 010_153507.eep Analising EEPROM... Phone IMEI:352202040188092 SimLock Data Cleared! Writing ... Sending SEC pack... Unlock done! Finished in 10 seconds After reading codes 2945#*360# it ask for spck not nck Whn enter readed codes code failed ,where is problem plz help Thanks |
08-21-2010, 13:03 | #3 (permalink) |
No Life Poster Join Date: Aug 2006 Location: On Earth
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | Just Now Iam also same problem facing here.Please Z3X Team Give us Solution for this problem.My handset is also asking SPCK Code.Now what can we do now? Here is the log file: Please reconnect phone battery / power source. Loading module , please wait... PMB8877 Module 1.2 started. SW: Ver 2.2.7.3 Connecting to GM360 in UART Mode (COM6 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8877) prebooting... Release power button. Booting... Reading info... BOOT Stage Finished , sending authority... Sending SEC pack... Reading EEPROM... Analising EEPROM... Phone IMEI:352202041120268 Unlock codes: NCK[0]: 1172699660967349 (LOCKED) Finished in 2 seconds Repairing EEPROM... Function not avaiable for this model Finished in 0 seconds Unlocking... Sending SEC pack... Reading ... Analising EEPROM... Phone IMEI:352202041120268 SimLock Data Cleared! Writing ... Sending SEC pack... Unlock done! Finished in 6 seconds |
08-21-2010, 13:05 | #4 (permalink) | |
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | Quote:
08-22-2010, 13:09 | #5 (permalink) |
Freak Poster Join Date: Feb 2005 Age: 46
Member: 112392 Status: Offline Thanks Meter: 11 | Reading info... BOOT Stage Finished , sending authority... Sending SEC pack... Reading EEPROM... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\GM360GO_autobackup_220 82010_170308.eep Analising EEPROM... Phone IMEI:35220xxxxxxxxxxxxxx Unlock codes: NCK[0]: 2547349578900865(LOCKED) Finished in 5 seconds Reading EEPROM Sending SEC pack... Analising EEPROM... Phone IMEI:352202040188092 For operation finishing,do next : 1. power phone ON with original SIM 2. type 2945#*XXX# ,where XXX are model digits to enter unlock menu 3. Enter one of this code(s): NCK[0]: 2547349578900865 (LOCKED) NCK[1]: 7065306085388965 (NS) NCK[2]: 1234509346672937 (SP) NCK[3]: 6752468935332620 (CP) Finished in 4 seconds Select Read codes ur problem will be solved |
The Following User Says Thank You to zeeshankhadim For This Useful Post: |
09-17-2010, 12:23 | #6 (permalink) | |
Freak Poster Join Date: Jul 2008 Location: china
Member: 817951 Status: Offline Sonork: 100.1584874 Thanks Meter: 52 | Quote:
HI DO U ONLY USE USB CABLE ? OR USE rj45 CABLE ?THX B.R | |
01-04-2011, 20:12 | #7 (permalink) |
Freak Poster Join Date: May 2009 Location: Vendas Novas, Portugal
Member: 1023337 Status: Offline Sonork: 100.1617970 Thanks Meter: 16 | hi, i can´t read info of the phone! here the log... Loading module , please wait... PMB8877 Module 1.2 started. SW: Ver 2.2.8.0 Connecting to GM360 in UART Mode (COM4 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:UNK:AA) prebooting... Release power button. Booting... Warning: Read LDP CRC Error... GOT:4005 , EXPECTED:ED3F Reading info... Main Loader answer timed OUT! BOOT Failed ***Disconnected*** TIP: Please reconnect phone battery / power source. |
09-22-2011, 11:20 | #8 (permalink) |
Freak Poster Join Date: May 2008 Location: united kingdom hull city
Member: 772904 Status: Offline Thanks Meter: 21 | lg gm360 unlock successful with cable lg gs102 Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\LG GM360_autobackup_22092011_105947.eep Analising EEPROM... Detailed Phone Information: Phone Model: GM360 Phone Manufacturer: LG Elec. Inc Phone Version: Jun 05 2009 Phone IMEI : 35220204682132400 Phone BT Adress : 5C:173:BA:AE:70 Detailed Codes Information: Phone NCK Code : 1177-7353-3698-7409 Phone NS Code : 8668-0871-2981-1231 Phone SP Code : 2754-3869-8764-9522 Phone CP Code : 3215-4526-2857-6753 Phone SIM Code : 4276-0591-7495-8282 SimLocks Disabled SP Lock Enabled CP Lock Disabled NS Lock Disabled SIM Lock Disabled AT Lock Disabled SL Config: Finished in 3 seconds Reading EEPROM Sending SEC pack... Analising EEPROM... Detailed Phone Information: Phone Model: GM360 Phone Manufacturer: LG Elec. Inc Phone Version: Jun 05 2009 Phone IMEI : 35220204682100000 Phone BT Adress : 5C:173:BA:AE:70 Detailed Codes Information: Phone NCK Code : 1177-7353-3698-7409 Phone NS Code : 8668-0871-2981-1231 Phone SP Code : 2754-3869-8764-9522 Phone CP Code : 3215-4526-2857-6753 Phone SIM Code : 4276-0591-7495-8282 For operation finishing,do next : 1. power phone ON with original SIM 2. type 2945#*XXX# ,where XXX are model digits to enter unlock menu 3. Enter one of this code(s): Finished in 3 seconds 1- select read codes and press unlock 2. Power on your LG Viewty GM360 with the original SIM card in. 3. Enter 2945#*360# 4. A menu will pop up, select SIM Unlock. 5. Enter your unlock code and hit OK. |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
