Old 05-26-2016, 00:02   #1 (permalink)
Member: 2439098
Thanks Meter: 2
Lg h830 unlock!
HI i need help please!
im trying to unlock Tmobile LG G5 H830
Having issues with selecting the H850 Model. Says not supported when i try to unlock in download mode....
What else can i do?
I try without being in download mode and i get this:
Mode: Normal
Model:
Build version: xð~
SW Version:
IMEI: BAD IMEI
BlueTooth Address: 00:00:00:7E:BB:01
Phone Code:
Elapsed: 0 secs. --> (v9.14)
Checking phone at COM26
No answer from phone
Elapsed: 4 secs. --> (v9.14)
This phone are not supported , or can be unlocked by patch!
THIS IS WITH SELECTED : MANUAL CHOICE OF MODEL
This is without selected : Manual choice of model
Mode: Normal
Model:
Build version: xð~
SW Version:
IMEI: BAD IMEI
Phone Code:
This phone are not supported!
Old 05-26-2016, 03:39   #2 (permalink)
Member: 2439098
Thanks Meter: 2
Can anyone help me please?!
Old 05-26-2016, 06:13   #3 (permalink)
Member: 2543524
Thanks Meter: 11
Doesn't the LG G5 T-Mobile require Device App Unlock ........I'm 90% sure .....only unlock via imei ...sorry
Sent from my SM-G930T using Tapatalk
Old 05-26-2016, 08:20   #4 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
1. For connect phone you must enable diag. (*#546368#*830#).
2. Unlock this phone not possible. Use server unlock with device unlock app.
The Following 2 Users Say Thank You to andrew_tm For This Useful Post:
Old 05-26-2016, 13:05   #5 (permalink)
Member: 2439098
Thanks Meter: 2
how do i use the unlock app. im in canada where tmobile not available? What if i repair imei will it be unlocked then?
Old 05-26-2016, 13:29   #6 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Search in unlock code services. You buy unlock via imei. After this turn on wifi and run device unlock app. Press button in app and your phone unlocked.
Imei repair not help you.
Old 01-17-2017, 14:32   #7 (permalink)
Member: 1362565
Thanks Meter: 2
Hi i get to this menu how can i put my unlock codes?
Sent from my Nexus 6 using Tapatalk
Old 01-17-2017, 14:40   #8 (permalink)
Member: 1362565
Thanks Meter: 2
I get the unlock code from the supplier... but i cant put it on the phone there is network unlock menu????
Old 01-17-2017, 14:40   #9 (permalink)
Member: 1362565
Thanks Meter: 2
H830 lg
Old 01-17-2017, 21:40   #10 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
2945#*830#
Old 01-18-2017, 06:15   #11 (permalink)
Member: 1362565
Thanks Meter: 2
2945#*830#
Old 01-18-2017, 06:16   #12 (permalink)
Member: 1362565
Thanks Meter: 2
2945#*830# not working on this phone...
Old 01-18-2017, 11:13   #13 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
If this Tmobile use Device Unlock App from phone menu.
Old 08-10-2018, 16:02   #14 (permalink)
Member: 1852923
Thanks Meter: 2
"Failure in processing the request. Please reboot device and try again."
I have encountered this problem. But when the message came out, everything seemed unsuccessful
Old 08-10-2018, 19:38   #15 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Use 9.52 and unlock by server credits.
The Following User Says Thank You to andrew_tm For This Useful Post:
Page generated in 0.20439 seconds with 8 queries
