01-27-2017, 11:25 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: syria Age: 42
Member: 248056 Status: Offline Sonork: 100.1605008 Thanks Meter: 11 | Lg h831 unlock problem not detected in normal mode all driver ok and all sitting done . in download mode no problem H83120A ANDROID 7 |
01-27-2017, 12:04 | #2 (permalink) |
Freak Poster Join Date: Mar 2015 Location: bangladesh rajshahi
Member: 2368022 Status: Offline Thanks Meter: 75 | u use octppus latest version Remove SD and SIM cards from the phone; Connect powered-on phone to PC with Micro USB Type-C cable; Install necessary driver; Click "Unlock" button; Follow software instructions (prompts). Note: To connect the phone in Normal Mode, do one of the following: Enable "USB Debugging" mode; Type 277634#*# or *#546368#*831# or 3845*#831#, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled". |
