Old 04-13-2017, 14:30   #1 (permalink)
Member: 2031642
Thanks Meter: 8
LG K550 imei repair
I am trying to repair the lg k550 (stylo 2 plus) . Does anyone have the file needed to do so? Or can anyone help point me in the right direction to fix this imei? Thank you
Sent from my SM-G920T using Tapatalk
Old 04-13-2017, 19:40   #2 (permalink)
Member: 2277857
Thanks Meter: 68
No file needed. Just select K550 in LGTool, enable diag port and run IMEI repair
The Following User Says Thank You to brg7562 For This Useful Post:
Old 04-17-2017, 11:15   #3 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Hi,
Select K550 and read manual in software.
Old 01-10-2018, 00:34   #4 (permalink)
reyxito's Avatar
Member: 2549748
Thanks Meter: 212
I select k550 and enable diag port select imei and then repair and nothing
Sent from my SM-G955F using Tapatalk
Old 01-10-2018, 08:50   #5 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Install driver LGUnitedMobileDriver_S52MAN314AP22_ML_WHQL_Ver_3.1 4.1.exe
and connect phone in Charge Mode or MTP Mode.
Old 01-10-2018, 08:55   #6 (permalink)
Member: 703094
Thanks Meter: 23
repair imei to lgtools..
Old 01-10-2018, 08:57   #7 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
1. Run LG 2-3G Tool.
2. Select Model.
3. Software show manual and you read in Connections section how Enable diag.
4. After Enable Diag reconnect phone.
5. Select phone port.
6. Select in list Repair IMEI.
7. Press Repair button.
Old 01-10-2018, 20:52   #8 (permalink)
reyxito's Avatar
Member: 2549748
Thanks Meter: 212
I dnt know what im doing wrong... im trying to repair imei because bad imei and not signals keep searching.. well i select k550 and repair imei button after that get 0 imei in phone... then select repair imei 0 fix..put ramdom imei change the last two digits... but dont get signal... any solutions?
Old 01-10-2018, 20:53   #9 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
1. Post log here.
2. If no signal you need write QCN from other phone.
Old 01-10-2018, 22:06   #10 (permalink)
reyxito's Avatar
Member: 2549748
Thanks Meter: 212
Originally Posted by andrew_tm View Post
1. Post log here.
Unable to get comport information , check system
LG 2-3G Tool v9.43
supported models: 1543
Mode: Normal
Model: LGK550AT
Build version: Oct 13 201719:11:46Aug 09 201723:00:00LGK550AT
SW Version: MPSS.JO.1.2.c2.1-00028-8937_GENNS_PACK-1.109862.1
IMEI: 00000000000000-0
BlueTooth Address: 00:00:00:00:00:00
Phone Code: default
Elapsed: 2 secs. --> (v9.43)
Mode: Normal
Model: LGK550AT
Phone Code: default
Checking phone at COM29
Detected ID: 0000100C (MSM8909)
Reading ESN... OK
Read SPC...
Unlock SPC... OK
Backuping RFNV... OK
Backuping Feature Mask... OK
Backuping NV Item... OK
Backuping NV Item SIM1... OK
Backuping NV Item SIM2... OK
Backuping Provisioning Item Files... OK
Elapsed: 279 secs. --> (v9.43)
Mode: Normal
Model: LGK550AT
IMEI: BAD IMEI
BlueTooth Address: 2C:00:00:00:02:00
Phone Code: default
Elapsed: 1 secs. --> (v9.43)
Repair IMEI...
Reading ESN... OK
Read SPC...
Unlock SPC... OK
Phone mode is NORMAL
Switch to DOWNLOAD mode
Phone detected!
Read security zone...
Laf Protocol: 01000005
Model name: LG-K550
Software verion: K55020c
Android verion: 7.0
Target operator: TMO
Target country: US
IMEI: 000000000000000
Save part1... done
Save part2... done
Save part3... done
Sec zone saved: ..\Backup\K550_BAD_10012018_170013.lgsb1
Write security zone...
Erase part1... done
Erase part2... done
Erase part3... done
Reboot...
Phone detected!
Reading QCN file... OK
Unlock SPC... OK
Checking paths... OK
Restoring EFS Backup... OK
Restoring NV Items... OK
Restoring NV Item SIM1... OK
Restoring NV Item SIM2... OK
Restoring Provisioning Item Files... OK
Repair IMEI...
Search LG Modem port...
Detected LG Modem port at COM28
Repair done!
Elapsed: 499 secs. --> (v9.43)
This phone are not supported!
Repair IMEI...
Repair done!
Elapsed: 74 secs. --> (v9.43)
Mode: Normal
Model: LGK550AT
IMEI: 35435808801265-7
BlueTooth Address: 42:00:00:00:02:00
Phone Code:
but no signals keeps searching...
where i can bought another qcn? or where i can find one?
Old 01-10-2018, 22:13   #11 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Search other phone or ask other users. Try search in our section by K550 keyword and ask other users who unlock about backup (software auto save backup).
Page generated in 0.23198 seconds with 8 queries
