01-06-2012, 13:28 | #1 (permalink) |
Freak Poster Join Date: Feb 2009 Location: spain
Member: 980172 Status: Offline Thanks Meter: 85 | lg km 900 mismatching Welcome to Z3X LG Multi Platform TOOL Current OS : Windows Seven SP1 BUILD:6/7601 Welcome to Sgold3 Module!! Disconnected. TIP: Please reconnect phone battery / power source. Disconnected. TIP: Please reconnect phone battery / power source. Count supported models - 138 Loading module , please wait... PMB8878 Module 2.0 started. SW: Ver 3.7.1.3 Connecting to LG KM900 in UART Mode (COM3 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8868) prebooting... Release power button. Booting... Changing Speed... Reading info... BOOT Stage Finished , sending authority... and stop here???? |
01-06-2012, 13:37 | #2 (permalink) |
Member: 980172 Status: Offline Thanks Meter: 85 | in usb mode same... Welcome to Z3X LG Multi Platform TOOL Current OS : Windows Seven SP1 BUILD:6/7601 Welcome to Sgold3 Module!! Disconnected. TIP: Please reconnect phone battery / power source. Disconnected. TIP: Please reconnect phone battery / power source. Count supported models - 138 Loading module , please wait... PMB8878 Module 2.0 started. SW: Ver 3.7.1.3 Connecting to LG KM900 in USB Mode... Please connect phone , it must be powered off Phone found! (MCU:SG3_USB) prebooting... Flash ID: 00FF00 *Note in USB mode flash id can be incorrectly read* BOOT Stage Finished , sending authority... |
01-06-2012, 21:25 | #5 (permalink) |
Member: 980172 Status: Offline Thanks Meter: 85 | mismatshing again... Welcome to Z3X LG Multi Platform TOOL Current OS : Windows Seven SP1 BUILD:6/7601 Welcome to Sgold3 Module!! Disconnected. TIP: Please reconnect phone battery / power source. Disconnected. TIP: Please reconnect phone battery / power source. Count supported models - 138 Loading module , please wait... PMB8878 Module 2.0 started. SW: Ver 3.7.1.3 Connecting to LG KM900 in UART Mode (COM3 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8868) prebooting... Release power button. Booting... Changing Speed... Reading info... Force boot mode on! Finished in 23 seconds Detecting FLS File version... Preprocessing FLS File.... Starting Flash Applet Starting Flash Applet Opening "KM900AT-01-V10h-232-10-MAY-07-2009+1.fls"... Writing FLSSP:../../../wou_build/OPERA_AUSTRIA_H3G_RELEASE/MPEH_OPERA_AUSTRIA_H3G.dsp Sending SEC pack... Done FLSSP Writing FLS:STATIC_EEP:MPEH_OPERA_AUSTRIA_H3G.eep Sending SEC pack... Done FLS:STATIC_EEP Writing FLS:CODE:MPEH_OPERA_AUSTRIA_H3G.fls Sending SEC pack... Writing FLS:CODE:MPEH_OPERA_AUSTRIA_H3G.fls Done FLS:CODE Writing FLS:CUST_DISK:OPERA_AUSTRIA_H3G-CUST.dfat Sending SEC pack... Done FLS:CUST_DISK Writing FLS:ROOT_DISK:OPERA_AUSTRIA_H3G-ROOT.dfat Sending SEC pack... Done FLS:ROOT_DISK Writing FLS:USER_DISK:OPERA_AUSTRIA_H3G-USER.dfat Sending SEC pack... Done FLS:USER_DISK Writing FLS:PSIsi_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:PSI Writing FLS:SLB:slb_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:SLB Writing FLS:UA:ua_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:UA Writing FLS:AMD_SINGLE:a250_single_image.fls Sending SEC pack... Certificate Failed! TIP: For KM900 and etc. phones use USB flashing mode , if UART fails. Finished in 214 minutes 37 seconds. |
01-09-2012, 20:25 | #6 (permalink) |
Member: 980172 Status: Offline Thanks Meter: 85 | solved by lgtool setool.best regard Flashing firmware from D:/KM900AT-01-V10t-214-01-MAY-20-2009+4.sbf Disconnect battery and connect cable to the phone Device found Setting up configuration Looking for GPT Creating backup in: Backups\KM900_35215403740910800_2.sbf Dumping block 1/2 Dumping block 2/2 Flashing PSI Flashing SLB Erasing DYN SDS Flashing partition 1/8 Region 1/2 Region 2/2 Flashing partition 2/8 Flashing partition 3/8 Flashing partition 4/8 Flashing partition 5/8 Flashing partition 6/8 Flashing partition 7/8 Flashing partition 8/8 Flashing firmware success (13:21) |
Alvatel OT30x Bulgarian LG | Permonik | Alcatel & TCL Old Models | 2 | 02-16-2002 16:56 |
v66/t191 are they 900/1800 | F C | Motorola P2k | 1 | 01-16-2002 16:24 |
I need lg with EAAHNIKA for X35 | alruus | x1x to x45/x50 | 0 | 11-22-2001 12:44 |
SW ASIC MISMATCH At 5110 | jonwillow | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-30-2001 09:53 |
NEED ANYTHING, SOFTWARE, RINGTONES, 900 NOL´S | jonthe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-27-2000 03:10 |
