10-26-2011, 16:55 | #1 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1144723 Status: Offline Thanks Meter: 9 | Lg ku 990i yellow screen I UNLOCKED LG KU990I and now yellow screen with unaivable otp block i tried to flash it with v10a and then i write the good nvm then i flash it an other time with v10d-ku990i with media and module files from the v10a but always yellow screen i flash it on emergy mode and normal:same problem what is the solution ) thx ziedgsm br |
10-26-2011, 18:00 | #4 (permalink) |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | flash in phone 10b open eur firmware. after flash check in option: manual select model select in model list kc910 press unlock in unlock dialog window select restore from backup after this phone start normal now select in model list ku990 (without i) make unlock must work. -- |
10-26-2011, 18:23 | #7 (permalink) |
Member: 445973 Status: Offline Thanks Meter: 3,489 | KU990i-DZ-V10b-MAR-12-2009-OPN-EU.crp in any mode. If you flash in emergency mode you must check in options manual model select and select ku990i(ku990i in emergencu mode detected how ku990). -- |
10-26-2011, 19:00 | #10 (permalink) |
Member: 1144723 Status: Offline Thanks Meter: 9 | hi i flash it without problem but after when i tried to unlock it i had message error what is problem? thx br v.2.1.1 supported models: 161 andrew_tm 2010(c) Reading file as KU990i... Ok Original Firmware file: KU990i-DZ-V10b-MAR-12-2009-OPN-EU Mode: Normal Model: KU990i Build version: Mar 22 200917:28:48MAR 20 200917:00:00KU990i SW Version: KU990i-MSM6280-V10d-MAR-20-2009-XX IMEI: 35994402899783-3 BlueTooth Address: 00:22:A9D:FF:57 Flash Name: toshiba_tya000bc00bogg Flash Info: 06C3/0040/0800 Elapsed: 0 secs. --> (v.2.1.1) Mode: Normal Model: KU990i Build version: Mar 22 200917:28:48MAR 20 200917:00:00KU990i SW Version: KU990i-MSM6280-V10d-MAR-20-2009-XX IMEI: 35994402899783-3 BlueTooth Address: 00:22:A9D:FF:57 Flash Name: toshiba_tya000bc00bogg Flash Info: 06C3/0040/0800 Elapsed: 0 secs. --> (v.2.1.1) NV read... NV save:..\backup\KU990i_359944028997833_26102011_192 129.cnv Elapsed: 57 secs. --> (v.2.1.1) Start Flash... Modem Write Start... Flash Verify Done. EFS Erase Done. Modem Write Done. Phone Reboot. Phone Detected! Write NV... EFS Write Start... Start Write Media... Start Write Module... EFS Write Done. Flash Done. Elapsed: 1791 secs. --> (v.2.1.1) Mode: Normal Model: KU990i Build version: Mar 31 200920:23:46FEB 13 200917:00:00KU990i SW Version: KU990i-MSM6280-V10b-MAR-12-2009-XX IMEI: 35994402899783-3 BlueTooth Address: 00:22:A9D:FF:57 Flash Name: toshiba_tya000bc00bogg Flash Info: 06C3/0040/0800 Elapsed: 0 secs. --> (v.2.1.1) Send loader... Loader startup Ok! Init NAND Ok! Error read page... Elapsed: 12 secs. --> (v.2.1.1) Mode: Normal Model: KU990i Build version: Mar 31 200920:23:46FEB 13 200917:00:00KU990i SW Version: KU990i-MSM6280-V10b-MAR-12-2009-XX IMEI: 35994402899783-3 BlueTooth Address: 00:22:A9D:FF:57 Flash Name: toshiba_tya000bc00bogg Flash Info: 06C3/0040/0800 Elapsed: 0 secs. --> (v.2.1.1) Send loader... Loader startup Ok! Init NAND Ok! Error read page... Elapsed: 12 secs. --> (v.2.1.1) |
6110 LCD Screen | gsmxc | Nokia Hardware & Hardware Repair | 4 | 06-26-2004 06:03 |
6110 and 3210 LCD Screen | pks | Nokia Hardware & Hardware Repair | 12 | 04-24-2001 12:45 |
8890 LCD SCREEN | erikiiy | Nokia Hardware & Hardware Repair | 0 | 12-21-2000 23:37 |
Screening indicator | cxara | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-09-1999 09:13 |
