01-27-2015, 21:13 | #16 (permalink) |
Freak Poster Join Date: Jul 2003 Location: CCCP Age: 54
Member: 34145 Status: Offline Thanks Meter: 16 | I personally cant get LTE sign in data mode and phone don't see LTE frequencies ... |
01-28-2015, 00:22 | #17 (permalink) |
Member: 34145 Status: Offline Thanks Meter: 16 | Just for fun - restored full EFS backup made before IMEI repair, set LTE only mode in *#*#INFO#*#* menu - and i can get LTE connection without any problem : But after IMEI repair - there's no network if i switch to LTE only mode ... Please, can anyone after nexus 5 IMEI repair - go to *#*#INFO#*#* , select "Phone information" , set network mode to "LTE only" and write here if phone can get LTE connection after imei repair. Thank you, R. |
01-29-2015, 16:20 | #20 (permalink) |
Member: 34145 Status: Offline Thanks Meter: 16 | Ok, problem solved, LTE is working after IMEI repair (D821), big thanks @andrew_tm ! Best support ever !!! BR R. |
The Following User Says Thank You to Rolf2 For This Useful Post: |
02-11-2015, 13:20 | #22 (permalink) |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | Use last software version and correct select model. If you have D820 select D820, if your model D821 select D821. Because this phone have different LTE frequency. P.S. I online in team viewer. -- |
02-11-2015, 23:38 | #25 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2331388 Status: Offline Thanks Meter: 1 | If I select model D820/D821 and "Read QCN" or "Read NVM" software version 6.5 will display "Please select correct device model manual" and then auto-select D802 *while* performing the task ("Read Info" shows model AAAAANAZ). Are the resulting files (named D802_IMEI***) OK or should I wait for an update? Last edited by ufcuvksc; 02-11-2015 at 23:47. |
The Following User Says Thank You to ufcuvksc For This Useful Post: |
02-12-2015, 00:17 | #26 (permalink) |
Member: 445973 Status: Offline Thanks Meter: 3,489 | Select your model and check in options : manual choice of model. Read this post: http://forum.gsmhosting.com/vbb/f453...l#post10859112 User make step2step manual. -- Last edited by andrew_tm; 02-12-2015 at 00:23. |
The Following User Says Thank You to andrew_tm For This Useful Post: |
03-05-2015, 23:25 | #30 (permalink) | |
No Life Poster Join Date: Aug 2013 Location: Somewhere on earth
Member: 2014742 Status: Offline Thanks Meter: 167 | Quote:
So my question: is it possible/safe to downgrade? Current intefaces: mtp,adb Enable diagnostic port Device not found! Elapsed: 164 secs. --> (v6.8) | |
