07-21-2014, 09:56 | #1 (permalink) |
Registered User Join Date: Apr 2010
Member: 1290061 Status: Offline Thanks Meter: 61 | LG P769 imei repair I check the imei in the phone and it is good. Phone keeps Searching never catches signal. Phone is MetroPcs P769 Anyone have a solution ? i can post the dump if anyone wants it. |
07-23-2014, 00:23 | #3 (permalink) |
Member: 1290061 Status: Offline Thanks Meter: 61 | LG 2-3G Tool v4.4 supported models: 820 For connect phone type 3845#*769#, open Port Setting menu, select CP Reset and Press Ok! Wait for device... OK Get loaders from... OK Send preloader... OK Send loader... OK Checking Flash ID... OK Detected Flash ID: 00B100AD Read flash... OK Get security from flash dump... OK IMEI: 013647001904XXX BlueTooth: 30:76:6F:76:0A:38 Sec zone saved: C:\Program Files (x86)\Z3X\LG\LGTool\Backup\P769_013647001904XXX_20 072014_205529.lgsb Put security to dump... OK Erase flash... OK Write flash... OK Repair IMEI OK Elapsed: 119 secs. --> (v4.4) First Dump of the phone by z3x https://mega.co.nz/#!CE0D0DTD!7XzXau...nkx-J2t9lGWjIk Last edited by george241312; 07-23-2014 at 00:33. |
07-23-2014, 21:52 | #5 (permalink) |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | In next 2-3 day I write your backup in my phone and check. Now more work and you must wait. Before unlock network work fine? Try make factory reset. -- |
The Following User Says Thank You to andrew_tm For This Useful Post: |
07-28-2014, 20:46 | #8 (permalink) |
Member: 445973 Status: Offline Thanks Meter: 3,489 | Yes exist problem and we work for fix this. Problem not only in your phone. Wait update. -- |
