Old 11-05-2018, 03:30   #1 (permalink)
Member: 2529251
Thanks Meter: 275
Lg phoenix 4 at&t cricket x210cmr x210apm unlock guide
LG PHOENIX 4 AT& T CRICKET X210CMR X210APM UNLOCK GUIDE Z3X 100%
This was a pain in rear this phone.
Ok root first doing this
X212TMB X210 ROOT INSTRUCTIONS & UNLOCK GUIDE 100%
1)Enable developer options (7x build number) > usb debugging and oem
unlock if present
back up all on the phone, it will be factory reset
(you will need adb fastboot installed newbeis use search)
2) open adb windows and enter following commands
adb kill-server
adb kill-server
adb devices ( press always allow checkbox on phone then OK)
adb reboot bootloader
fastboot oem unlock (this will erase phone be sure all backed up before issueing this command)
fastboot flash boot root_boot.img
then reboot phone
after it boots up setup (can skip everything then enable usb debugging as before)
adb install MagiskManager-v5.5.5.apk
(Or downlaod and install to phone your choice)
after its installed send command
adb shell
(in shell) > su
(on phone will appear another popup to grant root access, tap grant)
DONE....PHONE ROOTED
ROOT FILE LINK
https://1drv.ms/u/s!Amgp3kjCdk9PolLZCfwTB5s4ZL5B
NOW TO UNLOCK
SELECT MODEL LG- M150
SELECT NEW METHOD SERVER CREDITS 5$
LG 2-3G Tool v9.58
supported models: 1567
Mode: Normal
Model: LMX210AP
Build version: Jun 4 201818:54:00Dec 21 201705:00:00LMX210AP
SW Version: MPSS.JO.3.0.c8-00004-8937_GENNS_PACK-1
IMEI: 3539xxxxxxxxxxxxxxxxxx1
IMEI2: 00000000000000-0
BlueTooth Address: 00:00:01:02:26:00
Phone Code:
Elapsed: 1 secs. --> (v9.58)
Mode: Normal
Model: LMX210AP
IMEI: 35393xxxxxxxxxxxxx
Phone Code:
Checking Login and Password... OK
Ballance: 15 crd.
You have 15 credit(s) left. This operation takes 5 credits.Continue? Yes
Check adb server status... OK
Phone mode is NORMAL
Switch to DOWNLOAD mode
Phone detected!
Read security zone...
Laf Protocol: 00000001
Model name: LM-X210APM
Software verion: X210APM10c
Android verion: 7.1.2
Target operator: ATT
Target country: US
Chipset: msm8937
IMEI: 353934091103401
Save part1... done
Save part2... done
Save part3... done
Sec zone saved: ..\Backup\M150_353934091103401_04112018_211742.lgs b1
Detecting write method...
Init write method... fail
Init misc method... fail
Init sign method...
Execute sign method... done
Checking sign method...
Laf cmd info: send LAF_CMD_KILO, retry #1 done
Reboot...
Phone detected!
Search LG Modem port...
Detected LG Modem port at COM879
Read data from phone...
Checking adb...
SW Version: X210APM
Searching server...
Waiting for server answer...
Unlock done!
Elapsed: 224 secs. --> (v9.58)
Say thanks and enjoy unlocked LG PHOENIX 4 AT&T CRICKET
The Following 4 Users Say Thank You to cyc0d3d For This Useful Post:
Old 11-05-2018, 05:34   #2 (permalink)
Member: 2569104
Thanks Meter: 42
i think both models are already supported without root since version 9.57
The Following User Says Thank You to robertyanta83 For This Useful Post:
Old 11-05-2018, 16:27   #3 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
This isn't right manual. For unlock model you can't need root.
Old 11-07-2018, 19:52   #4 (permalink)
Member: 966403
Thanks Meter: 5
does this work for permanent locked x210cmr ?
Old 11-07-2018, 19:57   #5 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Must work if you mean X210 cricket.
Old 11-11-2018, 05:31   #6 (permalink)
Member: 966403
Thanks Meter: 5
yes x210 cricket. The one I have doesn't take the unlock code and the counter remains at 10 attempts.
Old 11-11-2018, 09:36   #7 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
We support unlock this model with full counter.
Old 01-06-2019, 22:49   #8 (permalink)
Member: 2641995
Thanks Meter: 2
Thumbs down
cyc0d3d, I followed your instructions to the Tee. However, after I flashed the root_boot file and the phone booted up, I was unable to use the touchscreen and the pixels of the screen looked out of place after pressing the sleep/wake key. After pressing the sleep/wake again, the screen just stays black until I reset the battery.
Any idea on how to unbrick this. No firmware for X210APM.
Hmm I should have done more research to find out that you don't need root for this phone. Not sure why I read this thread, I guess it made me believe that you did need root. Just ended up wasting money and time.
Old 01-07-2019, 10:14   #9 (permalink)
Member: 2529251
Thanks Meter: 275
This post pre dates the unlock method you refer to. If you need help fixing the device can message me directly. Be glad to help there is firmware for this
Sent from my BBD100-1 using Tapatalk
The Following User Says Thank You to cyc0d3d For This Useful Post:
Old 01-07-2019, 13:14   #10 (permalink)
Member: 570089
After flashing, touch not working
Old 01-08-2019, 17:55   #11 (permalink)
Member: 2641995
Thanks Meter: 2
Hi cyc0d3d. I PMed you. Could you provide the firmware or a fix for this?
Old 02-09-2019, 16:54   #12 (permalink)
Member: 115573
Thanks Meter: 102
same problem,
need firmware for lg x210apm
thx
The Following User Says Thank You to okbadz For This Useful Post:
Old 02-10-2019, 17:29   #13 (permalink)
Member: 115573
Thanks Meter: 102
fixed
fixed !!
extract boot.bin from version X210MA10k_00_MPCS_US_OP_0816 "boot_409600.bin" same as x210apm10h
fastboot flash boot boot_409600.bin
enjoy touch fixed
x210amp supported without root since version 9.57
The Following 2 Users Say Thank You to okbadz For This Useful Post:
Old 02-10-2019, 19:08   #14 (permalink)
Member: 115573
Thanks Meter: 102
Originally Posted by okbadz View Post
fixed !!
enjoy touch fixed
boot_409600
Old 04-24-2019, 19:28   #15 (permalink)
Gambitv01's Avatar
Member: 1475064
Thanks Meter: 347
new version is out for the pheonix 4 lm-x210apm this method not working no more
Page generated in 0.23149 seconds with 8 queries
