Lg phoenix 4 at&t cricket x210cmr x210apm unlock guide LG PHOENIX 4 AT& T CRICKET X210CMR X210APM UNLOCK GUIDE Z3X 100% This was a pain in rear this phone. Ok root first doing this X212TMB X210 ROOT INSTRUCTIONS & UNLOCK GUIDE 100% 1)Enable developer options (7x build number) > usb debugging and oem unlock if present back up all on the phone, it will be factory reset (you will need adb fastboot installed newbeis use search) 2) open adb windows and enter following commands adb kill-server adb kill-server adb devices ( press always allow checkbox on phone then OK) adb reboot bootloader fastboot oem unlock (this will erase phone be sure all backed up before issueing this command) fastboot flash boot root_boot.img then reboot phone after it boots up setup (can skip everything then enable usb debugging as before) adb install MagiskManager-v5.5.5.apk (Or downlaod and install to phone your choice) after its installed send command adb shell (in shell) > su (on phone will appear another popup to grant root access, tap grant) DONE....PHONE ROOTED ROOT FILE LINK https://1drv.ms/u/s!Amgp3kjCdk9PolLZCfwTB5s4ZL5B NOW TO UNLOCK SELECT MODEL LG- M150 SELECT NEW METHOD SERVER CREDITS 5$ LG 2-3G Tool v9.58 supported models: 1567 Mode: Normal Model: LMX210AP Build version: Jun 4 201818:54:00Dec 21 201705:00:00LMX210AP SW Version: MPSS.JO.3.0.c8-00004-8937_GENNS_PACK-1 IMEI: 3539xxxxxxxxxxxxxxxxxx1 IMEI2: 00000000000000-0 BlueTooth Address: 00:00:01:02:26:00 Phone Code: Elapsed: 1 secs. --> (v9.58) Mode: Normal Model: LMX210AP Build version: Jun 4 201818:54:00Dec 21 201705:00:00LMX210AP SW Version: MPSS.JO.3.0.c8-00004-8937_GENNS_PACK-1 IMEI: 35393xxxxxxxxxxxxx IMEI2: 00000000000000-0 BlueTooth Address: 00:00:01:02:26:00 Phone Code: Elapsed: 1 secs. --> (v9.58) Checking Login and Password... OK Ballance: 15 crd. You have 15 credit(s) left. This operation takes 5 credits.Continue? Yes Check adb server status... OK Phone mode is NORMAL Switch to DOWNLOAD mode Phone detected! Read security zone... Laf Protocol: 00000001 Model name: LM-X210APM Software verion: X210APM10c Android verion: 7.1.2 Target operator: ATT Target country: US Chipset: msm8937 IMEI: 353934091103401 Save part1... done Save part2... done Save part3... done Sec zone saved: ..\Backup\M150_353934091103401_04112018_211742.lgs b1 Detecting write method... Init write method... fail Init misc method... fail Init sign method... Execute sign method... done Checking sign method... Laf cmd info: send LAF_CMD_KILO, retry #1 done Laf cmd info: send LAF_CMD_KILO, retry #1 Laf cmd info: send LAF_CMD_KILO, retry #1 Laf cmd info: send LAF_CMD_KILO, retry #1 Reboot... Phone detected! Search LG Modem port... Detected LG Modem port at COM879 Read data from phone... Check adb server status... OK Checking adb... SW Version: X210APM Searching server... Waiting for server answer... Unlock done! Elapsed: 224 secs. --> (v9.58) Say thanks and enjoy unlocked LG PHOENIX 4 AT&T CRICKET |
i think both models are already supported without root since version 9.57 |
This isn't right manual. For unlock model you can't need root. -- :) |
does this work for permanent locked x210cmr ? |
We support unlock this model with full counter. -- :) |
cyc0d3d, I followed your instructions to the Tee. However, after I flashed the root_boot file and the phone booted up, I was unable to use the touchscreen and the pixels of the screen looked out of place after pressing the sleep/wake key. After pressing the sleep/wake again, the screen just stays black until I reset the battery. Any idea on how to unbrick this. No firmware for X210APM. Hmm I should have done more research to find out that you don't need root for this phone. Not sure why I read this thread, I guess it made me believe that you did need root. Just ended up wasting money and time. |
Sent from my BBD100-1 using Tapatalk |
After flashing, touch not working |
Hi cyc0d3d. I PMed you. Could you provide the firmware or a fix for this? |
same problem, After flashing, touch not working need firmware for lg x210apm thx |
fixed fixed !! :) :) extract boot.bin from version X210MA10k_00_MPCS_US_OP_0816 "boot_409600.bin" same as x210apm10h fastboot flash boot boot_409600.bin enjoy touch fixed x210amp supported without root since version 9.57 |
new version is out for the pheonix 4 lm-x210apm this method not working no more |
