05-29-2009, 01:17 | #1 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 567388 Status: Offline Thanks Meter: 24 | lg u900 how to unlock with procedure please. i use cable U8110F ang usb insert to the box.... heres the logs.... v.1.5.0 supported models: 57 andrew_tm 2009(c) Mode: Normal Model: U900 Build version: May 05 200614:00:19MAY 05 200612:00:00U900 SW Version: U900-MSM6250A-V10b-MAY-05-2006-H3G-LatIT IMEI: 35930400018260-3 BlueTooth Address: 00:12:56:31:A6:AA Elapsed: 1 secs. |
The Following User Says Thank You to dj nike For This Useful Post: |
05-29-2009, 02:32 | #2 (permalink) |
Member: 567388 Status: Offline Thanks Meter: 24 | when i flash i got this error... v.1.5.0 supported models: 57 andrew_tm 2009(c) Mode: Emergency Model: U900-MSM6250A-V10b-M‚–~ Elapsed: 0 secs. Mode: Normal Model: U900 Build version: May 10 200616:23:11MAY 10 200612:00:00U900 SW Version: U900-MSM6250A-V10b-MAY-10-2006-H3G-LatIT IMEI: 35930400018260-3 BlueTooth Address: 00:12:56:31:A6:AA Elapsed: 0 secs. Reading file as U900... Ok Original Flash File: U900_V11-Sep-17-2006-Patched-ALL-VERSIONS-UNLOCK Mode: Normal Model: U900 Build version: May 10 200616:23:11MAY 10 200612:00:00U900 SW Version: U900-MSM6250A-V10b-MAY-10-2006-H3G-LatIT IMEI: 35930400018260-3 BlueTooth Address: 00:12:56:31:A6:AA Elapsed: 0 secs. Start Flash... Modem Write Start... Flash Verify Done. EFS Erase Done. Modem Write Done. Phone Reboot. Phone Detected! EFS Write Start... Start Write Media... Start Write Module... EFS Write Done. Flash Done. Elapsed: 1319 secs. Mode: Normal Model: U900 Build version: May 10 200616:23:11MAY 10 200612:00:00U900 SW Version: U900-MSM6250A-V10b-MAY-10-2006-H3G-LatIT IMEI: 35930400018260-3 BlueTooth Address: 00:12:56:31:A6:AA Elapsed: 27 secs. Mode: Normal Model: U900 Build version: May 10 200616:23:11MAY 10 200612:00:00U900 SW Version: U900-MSM6250A-V10b-MAY-10-2006-H3G-LatIT IMEI: 35930400018260-3 BlueTooth Address: 00:12:56:31:A6:AA Elapsed: 0 secs. Not supported firmware! Flash phone! Elapsed: 0 secs. Mode: Normal Model: U900 Build version: May 10 200616:23:11MAY 10 200612:00:00U900 SW Version: U900-MSM6250A-V10b-MAY-10-2006-H3G-LatIT IMEI: 35930400018260-3 BlueTooth Address: 00:12:56:31:A6:AA Elapsed: 0 secs. Mode: Normal Model: U900 Build version: May 10 200616:23:11MAY 10 200612:00:00U900 SW Version: U900-MSM6250A-V10b-MAY-10-2006-H3G-LatIT IMEI: 35930400018260-3 BlueTooth Address: 00:12:56:31:A6:AA Elapsed: 0 secs. Not supported firmware! Flash phone! Elapsed: 0 secs. |
05-29-2009, 03:29 | #3 (permalink) |
No Life Poster Join Date: Sep 2006 Location: 102 quy nhơn BĐ Age: 14
Member: 347720 Status: Offline Sonork: xxx Thanks Meter: 204 | i think u need use new database unlock it ok or not supported firmware again ,u must read dump flash file send to support |
The Following User Says Thank You to freedomqn For This Useful Post: |
05-29-2009, 04:24 | #4 (permalink) |
Member: 567388 Status: Offline Thanks Meter: 24 | MY PROBLEM WAS SOLVE BY THIS THREAD...... http://forum.gsmhosting.com/vbb/show...highlight=u900 I FLASH THE PHONE WITH THIS VERSION...U900_V11G-JAN-23-2007-H3G-IT.crp v.1.5.0 supported models: 57 andrew_tm 2009(c) Select ComPort or use Search Phone button! Elapsed: 0 secs. Mode: Normal Model: U900 Build version: May 10 200616:23:11MAY 10 200612:00:00U900 SW Version: U900-MSM6250A-V10b-MAY-10-2006-H3G-LatIT IMEI: 359000000000 BlueTooth Address: 00:12:56:31:A6:AA Elapsed: 1 secs. Reading file as U900... Ok Original Flash File: U900-HCLSDR-V11g-Jan-23-2007-H3G-IT Mode: Normal Model: U900 Build version: May 10 200616:23:11MAY 10 200612:00:00U900 SW Version: U900-MSM6250A-V10b-MAY-10-2006-H3G-LatIT IMEI: 3593000000000 BlueTooth Address: 00:12:56:31:A6:AA Elapsed: 0 secs. Start Flash... Modem Write Start... Flash Verify Done. EFS Erase Done. Modem Write Done. Phone Reboot. Phone Detected! EFS Write Start... Start Write Media... Start Write Module... EFS Write Done. Flash Done. Elapsed: 882 secs. Mode: Normal Model: U900 Build version: Jan 23 200710:39:40JAN 23 200712:00:00U900 SW Version: U900-MSM6250A-V11g-JAN-23-2007-H3G-IT IMEI: 35930400018260-3 BlueTooth Address: 00:12:56:31:A6:AA Elapsed: 24 secs. Mode: Normal Model: U900 Build version: Jan 23 200710:39:40JAN 23 200712:00:00U900 SW Version: U900-MSM6250A-V11g-JAN-23-2007-H3G-IT IMEI: 35930400018260-3 BlueTooth Address: 00:12:56:31:A6:AA Elapsed: 0 secs. Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM45 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... - Start read nand... - Read nand done... Bad sectors detected! - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... Unlock done! Phone reboot! Elapsed: 60 secs. Mode: Normal Model: U900 Build version: Jan 23 200710:39:40JAN 23 200712:00:00U900 SW Version: U900-MSM6250A-V11g-JAN-23-2007-H3G-IT IMEI: 35930400018260-3 BlueTooth Address: 00:12:56:31:A6:AA Elapsed: 0 secs. NV file: U900_network_ok.cnv NV File Version: 1 NV File Model: U900 NV Records: 410 Write NV... Phone reboot! Elapsed: 8 secs. THANKS TO Z3X TEAM |
The Following 6 Users Say Thank You to dj nike For This Useful Post: |
HOW TO unlock SE v600i ??please help | xiongfuchen | SETool2 | 15 | 05-21-2013 08:10 |
LG U900 can be unlocked with multibox ? | vlad33 | Multi-Box | 1 | 05-01-2008 09:09 |
LG u900 how to unlock | fethi | LG | 13 | 08-18-2006 19:08 |
LG U900 how to upload java apps ? | indio68 | LG | 0 | 07-29-2006 11:03 |
How to unlock T720 [PROCEDURE] | PrinceOfEgypt | Motorola P2k | 7 | 05-23-2003 19:22 |
