05-11-2016, 08:02 | #1 (permalink) |
Freak Poster Join Date: May 2014
Member: 2183509 Status: Offline Thanks Meter: 68 | LG VS880K Not booting up completely: Gets stuck at Starting Apps.... Phone mode is DOWNLOAD Start FRP remove... Model name: VS880 Software verion: VS88024A Android verion: 5.1.1 IMEI: 352265065125505 Patching... Patching... FRP Reset Done. Elapsed: 61 secs. --> (v9.12) Mode: Emergency Model: VS880 Elapsed: 2 secs. --> (v9.12) Phone mode is DOWNLOAD Start FRP remove... Model name: VS880 Software verion: VS88024A Android verion: 5.1.1 IMEI: 352265065125505 Restore data detected! Restore DONE! Elapsed: 6 secs. --> (v9.12) |
05-11-2016, 21:04 | #3 (permalink) | |
Member: 2183509 Status: Offline Thanks Meter: 68 | Quote:
Thank you Andrew for your response. | |
05-11-2016, 21:05 | #4 (permalink) | |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | Quote:
You can read from other phone only system and write to this phone. If system same version how in your phone. -- | |
05-12-2016, 10:31 | #6 (permalink) |
Member: 445973 Status: Offline Thanks Meter: 3,489 | If you can read system from phone and upload to any file hosting. Sens link to me in pm. |
The Following User Says Thank You to andrew_tm For This Useful Post: |
05-13-2016, 00:47 | #7 (permalink) | |
Not detect phone! Please manual select port or reboot PC! Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 3 secs. --> (v9.10) Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 3 secs. --> (v9.10) I rebooted PC many times and swiched cables, but no difference. I may need to try on a different computer. | |
05-14-2016, 08:57 | #11 (permalink) |
Member: 2183509 Status: Offline Thanks Meter: 68 | Problem is solved. I had to flash the whole firmware read from another VS880 same version 24A and FRP is removed as well. Thank you Andrew for your support. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to noahark For This Useful Post: |
11-11-2018, 13:28 | #12 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | VS880 firmwares Version 24A https://lg-firmwares.com/downloads-f...A_03_ABR01.kdz Version 28A https://drive.google.com/file/d/1mXd...aY8CDnMty/view Last edited by BillA; 11-11-2018 at 13:38. |
