Old 04-30-2010, 10:39   #1 (permalink)
s4h
Member: 36569
Thanks Meter: 5
Z3X LG SGold3 cant start (Application Initialisation Failed)
I am using the latest SGold Version and latest Shell Version.
Please help me, here is Screen:
Old 04-30-2010, 11:15   #2 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
PLS REINSTALL THE SETUP.
WBR
sahil2000ind
Old 04-30-2010, 11:51   #3 (permalink)
Member: 844520
Thanks Meter: 26
just reinstall and enjoy bcoz i hade same problem but it sloved
Old 04-30-2010, 19:33   #4 (permalink)
s4h
Member: 36569
Thanks Meter: 5
i tryed to reinstall setup but same problem
shell version is 3.18, sgold version is 2.35.1
2G tool is working without problems
please help
Old 04-30-2010, 19:40   #5 (permalink)
mamepap's Avatar
Member: 532853
Thanks Meter: 610
desactive your antivirus and reinstall.
Old 05-01-2010, 09:07   #6 (permalink)
NoNameŽ's Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
Download 2.2.4 from support , and try to disable some AV software
Old 07-06-2010, 15:26   #7 (permalink)
Angelo Cruz's Avatar
Member: 8012
Thanks Meter: 124
I have the same problem with 2.2.7.1 or 2.2.7.2 version of SGOLD3.
No antivirus , firewall disabled , reeinstalled , reboot pc , everything and always same error.
Other modules running with no problem.
Any clue how to solve it?
AC
Old 07-06-2010, 16:20   #8 (permalink)
NoNameŽ's Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
Try to reinstall software , and run it with administrator rights
Old 07-06-2010, 16:23   #9 (permalink)
Member: 715596
Thanks Meter: 244
3G is working in Qualcomm Tool
Old 07-06-2010, 16:35   #10 (permalink)
Member: 8012
Thanks Meter: 124
Already reinstalled and i am running it as administrator it gives the same error.
It gives the error with or without box connected , the program doesn´t even get to check the card.
Old 07-06-2010, 23:52   #11 (permalink)
Member: 8012
Thanks Meter: 124
No more hints??
For sure there must be more users that faced the same problem.
Old 07-07-2010, 00:12   #12 (permalink)
NoNameŽ's Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
Strange problem , what os version you use ? I will try to get same build in VMVare environment and check. Maybe some AV software are running ?
Old 07-07-2010, 00:21   #13 (permalink)
Member: 8012
Thanks Meter: 124
Windows XP Home, i don´t think it has to do with OS , i have the same OS with the same build in another pc in another location and it works fine .
No AV installed in this PC, firewall disable, admin rights....
PS:. Check your PM please.
Old 07-21-2010, 13:29   #14 (permalink)
ziadi_alaeddin's Avatar
Member: 650956
Sonork: doki-doc gsm
Thanks Meter: 72
i have same problem, only solution for this bug """ reinstall system windows "" tested 100%
Old 12-07-2018, 01:22   #15 (permalink)
Member: 2028047
Thanks Meter: 17
Hi, I hope you can answer me, we are in 2018 with Windows 10 64bit. Everything works fine, but install the latest version of the program "LG_Sgold3_Tool_3.7.1.4_FIX.exe" and when it boots I get:
* First, a window indicating the following: "Not supported OS version".
Capture: https://prntscr.com/lrr0mm
* Second, the program detects my Box, Serial, etc. All good.
Capture: https://prntscr.com/lrr24w
* Third, I open the normal program without any problem, just that I have not yet tried with any phone in those series.
Capture: https://prntscr.com/lrr3zi
Is this normal and can I continue omitting this message, or should I worry and do something? :confuso:
GET ME STARTED igotthehookup Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-25-2001 07:56
antinokia flasher shell ver 2 (changing the start addresses) AMTX99 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-06-2001 11:12
I CANT GET DEJAN TO WORK! dario Nokia Hardware & Hardware Repair 1 01-27-2001 11:01
cant unlock CSI eeprom Stryker Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 9 08-20-2000 13:00
How do I change Start Up Logo? Digital Man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-29-2000 15:20
Page generated in 0.25783 seconds with 11 queries
