05-09-2009, 07:24 | #1 (permalink) |
Junior Member Join Date: Nov 2006 Location: phil Age: 41
Member: 392715 Status: Offline Thanks Meter: 132 | M120 Return for service? help.... Any way to clear this? Flashing no good solution and format ffs |
05-13-2009, 22:46 | #3 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 62
Member: 63042 Status: Offline Thanks Meter: 117 | @blang Yest spongevhong17 upload the needed read file at mega but was deleted for any reason we dont know! I hope uploading thru rapid as specified and put link here will help for z3x user problem.. http://rapidshare.com/files/23264195...rvice.rar.html |
The Following User Says Thank You to rakishi For This Useful Post: |
05-20-2009, 03:04 | #8 (permalink) |
Freak Poster Join Date: Feb 2005 Location: hk, phils.,shenzhen
Member: 120669 Status: Offline Thanks Meter: 15 | same problem... use lastest version already... Selected model -> M120 ---- with soft version -> 3.00 beta 0025 Phone must be ON! CONNECT PHONE TestModeOn - ok SoftWare-> M128ZCHC2 Langpack-> China, Hong Kong IMEI-> 35987101047586 S/N-> R5VQB77322 HW-> MP 0.101 Phone password-> 00000000 Sum Flash-> 1 Flash Prod ID-> 001 Flash Device ID-> 227e4200 Flash size-> 33554432 Bytes Flash sectors-> 262 sectors Bluetooth ID-> BT not found Status OTP-> OTP is ok ! MSL DEACTIVATED - TRUE Locks is inactive [NETLOCK]: Use #0111*55475153# for deactivate this lock [SIMLOCK]: Use #0141*00000000# for deactivate this lock Read info - ok Elapsed time: 12 second --------------------------------- Phone must be ON! Connect phone TestModeOn - ok MSL DEACTIVATED - TRUE Imei store to RAM Imei store to flash Repair - ok Elapsed time: 12 second --------------------------------- Phone must be ON! CONNECT PHONE TestModeOn - ok Repair OTP - ok Elapsed time: 7 second --------------------------------- Phone must be OFF with battery CONNECT PHONE Sync phone - ok Sync loader1 - ok bad ask - +ok+ Send loaders - fail Format FFS - false Elapsed time: 25 second --------------------------------- |
05-20-2009, 10:41 | #9 (permalink) |
Product Supporter Join Date: Aug 2007
Member: 561932 Status: Offline Thanks Meter: 168 | Repair OTP - is destructive function - use only for repair OTP. Format FFS - too(for repair blinking phone). Repair you phone - fill field Serial Numer from sticker phone - and press OTP. And without sim enter code for unlock phone. |
M120 Unlocked, but no luck! Still shows "Phone locked. Return for service." | rprosperojr | Z3X-Team Products | 4 | 07-21-2009 04:31 |
M120 Return for service? help.... | spongevhong17 | SPT BOX | 3 | 06-04-2009 04:39 |
E715 phone locked return for servicing HELP!!! | dime | Trident/AGERE Platform | 0 | 06-18-2005 10:34 |
A300 return for service - help? | genius123 | VLSI, Conexant, Skyworks and Old Models | 0 | 06-05-2004 23:44 |
Phone Locked Return for Servicing - Help!! | stroberscope | VLSI, Conexant, Skyworks and Old Models | 4 | 05-01-2003 00:19 |
