Old 11-07-2018, 19:07   #1 (permalink)
Member: 308068
Thanks Meter: 21
m150 Network locked
I tried to unlock LG M150 today and I got instead a network locked or permanently locked. How to fix it? here is my log:
Checking Login and Password... OK
Ballance: 45 crd.
You have 45 credit(s) left. This operation takes 5 credits.Continue? Yes
Check adb server status... OK
Checking phone at COM13
Detected ID: 0000100C (MSM8909)
SW Version: MPSS.JO.2.0.c1.2-00020-8909_GEN_PACK-1.92496.1.104247.1
Reading ESN... OK
Read SPC...
SPC: 000000
Unlock SPC... OK
Backuping RFNV... OK
Backuping Feature Mask... OK
Backuping NV Item... OK
Backuping NV Item SIM1... OK
Backuping NV Item SIM2... OK
Backuping Provisioning Item Files... OK
Phone mode is NORMAL
Switch to DOWNLOAD mode
Phone detected!
Read security zone...
Laf Protocol: 01000005
Model name: LG-M150
Software verion: M15020m
Android verion: 7.0
Target operator: ATT
Target country: US
Chipset: msm8909
IMEI: 355932091503107
Save part1... done
Save part2... done
Save part3... done
Sec zone saved: ..\Backup\M150_355932091503107_07112018_125248.lgs b1
Detecting write method...
Init write method... fail
Init misc method... fail
Init sign method...
Execute sign method... done
Checking sign method... done
Reboot...
Phone detected!
Reading QCN file... OK
Port open fail COM13
Elapsed: 560 secs. --> (v9.59)
Old 11-07-2018, 19:19   #2 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Hi,
Try remove from PC like LG Bridge. This software use modem port and our software can't open port.
Old 11-07-2018, 19:26   #3 (permalink)
Member: 308068
Thanks Meter: 21
What is LG Bridge? Or what is the method to solve this? Thanks
Old 11-07-2018, 19:58   #4 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Send to me in PM team viewer id and pass. I check your problem.
Old 11-07-2018, 22:03   #5 (permalink)
Member: 308068
Thanks Meter: 21
OkI have sent you a message with info requested.
Thanks
Old 11-07-2018, 22:23   #6 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Unlocked. User can't set MTP always and phone after reboot can't enable Diag and modem port.
Old 11-07-2018, 23:38   #7 (permalink)
Member: 308068
Thanks Meter: 21
Problem solved.
Z3 team you are the best
Thanks Andrew
The Following User Says Thank You to Globetel For This Useful Post:
Old 11-09-2018, 05:26   #8 (permalink)
Member: 139251
Thanks Meter: 16
Same problem with me, can you help me sir @andrew_tm?
Old 11-09-2018, 08:21   #9 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
select MTP in connections and press Always.
Page generated in 0.18289 seconds with 9 queries
