11-02-2018, 19:36 | #1 (permalink) |
No Life Poster Join Date: Jun 2016 Location: UK
Member: 2581848 Status: Offline Thanks Meter: 249 | SM-G950u problem unlock att [Answered] Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Unlocking using Server: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G950U Software version: 34.2 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G950U Android version: 8.0.0 PDA version: G950USQS5CRH1 CSC version: G950UOYN5CRH1 Phone version: G950USQS5CRH1 Product code: SM2G950UZSAATT CSC country code: USA CSC sales code: ATT Phone SN: R38J9001PYW IMEI: 3577230**** HW version: REV1.0 RF cal date: 2017.09.01 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-08-01 Boot Warranty bit: 0 SIM State: ABSENT Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM13 detected Reading data from phone... OK Calculating... error (0) Done with Samsung Tool PRO v.34.2 |
