09-16-2014, 17:50 | #1 (permalink) |
No Life Poster Join Date: May 2002 Location: TX Age: 49
Member: 12427 Status: Offline Thanks Meter: 78 | M919 4.4.4 qcn and getting this error with Z3X : Exception: Access violation at address 0055CF8C in module 'SamsungTool.exe'. Read of address 00000000 I tried to flash it with KIES, now it upgraded to 4.4.4 but the issue remain the same, still show searching. Any idea? |
10-20-2014, 21:56 | #4 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Somewhere on earth
Member: 2014742 Status: Offline Thanks Meter: 167 | Try writing the following qcn to it: Download GalaxyNote2/atthowto/enabletmo3g4g/ATT_I317_AWSMOD_dumimei.qcn at DownloadAndroidROM.com |
The Following User Says Thank You to A4L For This Useful Post: |
10-20-2014, 23:56 | #5 (permalink) |
Member: 12427 Status: Offline Thanks Meter: 78 | What so special about this qcn that would let me write to the phone? As mentioned on 1st post, I tried to restore qcn via QPST but keep getting error "Received an invalid command from the phone." and getting this error with Z3X : Exception: Access violation at address 0055CF8C in module 'SamsungTool.exe'. Read of address 00000000 |
10-21-2014, 04:33 | #6 (permalink) | |
Member: 2014742 Status: Offline Thanks Meter: 167 | Quote:
10-22-2014, 20:43 | #7 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | so, my question again, did you flash with KIES using the RECOVERY MODE of KIES? or you just flashed the phone ? there is a mode at KIES which when used, will cause KIES to fetch special data from samsung Servers and will write it to the phone... and yes, you should also try to write the .qcn file posted |
10-24-2014, 00:21 | #9 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | Don't even think on writing the i317 QCN not compatible! .... You will have random reboots etc .... ill make a mackup later on today when I get one .... But never try to write QCN Files from different models that are not compatible .... |
10-25-2014, 22:30 | #10 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Hi, I wrote this qcn file to m919 which was not registerin on any network. and it is working now without any reboots. or problem. I have been for a month trying to solve this problem until now that I wrote this .qcn file with Octopus (I could not write it with z3x, dunno why) so, thanks for the file. PD: before this I wrote a .qcn file from octopus support, named m919.qcn and it did not make the phone work. |
