04-22-2019, 13:48 | #16 (permalink) |
Freak Poster Join Date: Feb 2010 Location: P A K I S T A N Age: 43
Member: 1242837 Status: Offline Sonork: 100.1653310 Thanks Meter: 53 | >> Device Found! Reading Info............ MANUFACTURER : SAMSUNG HARDWARE : QCOM MODEL : SM-G935T BASEBAND : MSM BOARD : MSM8996 VERSION : 7.0 DEVICE TYPE : COUNTRY CODE : CONNECTION MODE : MTP,ADB Repair Mipi Success!! =========================== Hints : Popup Will Show , Go Setting , System , And Go To Rebuild Nvrm Then Reboot this method is 1000% working for me...... my set was mipi device failled error... and now my set is 100 % working fine..... this is money making.... post...... thank best regards.... Tausif Mughal |
07-16-2019, 09:43 | #17 (permalink) | |
Insane Poster Join Date: Jul 2017 Location: Bangladesh Age: 29
Member: 2740295 Status: Offline Thanks Meter: 33 | Quote:
Not show Pop-Up on J250F | |
The Following User Says Thank You to raju24.bd For This Useful Post: |
07-23-2019, 10:15 | #19 (permalink) |
No Life Poster Join Date: Feb 2006 Location: P A K I S T A N Age: 42
Member: 237155 Status: Offline Thanks Meter: 415 | install shortcut master lite. Go to secret code explorer and open 27663368378. You will be able to navigate from there to NVRAM Rebuild, though youll have to look it up for your device as the menu changes depending on the model and system. -------------------- more detail ---------------------- go to code 27663368378. click launch 0 ue setting & info setting system nv rebuild all mode. reboot and done. |
The Following 5 Users Say Thank You to quasim0438 For This Useful Post: |
07-25-2019, 16:38 | #20 (permalink) |
No Life Poster Join Date: May 2005 Location: bridgetown Age: 59
Member: 146939 Status: Offline Sonork: 100.1609615 Thanks Meter: 245 | 2766336837 use this no need root have to conect phone with z3x urt cable and then u put this code Popup Will Show , Go Setting , System , And Go To Rebuild Nvrm Then Reboot |
07-25-2019, 16:58 | #21 (permalink) |
The Following User Says Thank You to sweetboy For This Useful Post: |
08-26-2019, 16:46 | #24 (permalink) | |
Freak Poster Join Date: Dec 2008 Location: SKN Caribbean Age: 41
Member: 919402 Status: Offline Sonork: ky Thanks Meter: 93 | Thanks you are The Man, It work with G930A 7.0 binary U4. i try allot of method but only work with this. Quote:
The Following User Says Thank You to ky_bAttaUsAi For This Useful Post: |
10-14-2019, 22:46 | #26 (permalink) |
Junior Member Join Date: Nov 2012
Member: 1844330 Status: Offline Thanks Meter: 4 | for new devices model such s7 and s7 edge and all devices not rooted by cobination file mipi fixed follow: Fix Mipi Device Fail All New Bulids Tested | Yemen-Pro |
The Following User Says Thank You to alsharaby For This Useful Post: |
10-16-2019, 09:27 | #27 (permalink) |
Freak Poster Join Date: Apr 2019 Location: Afghanistan kabul Age: 24
Member: 2905715 Status: Offline Sonork: 100.1682585 Thanks Meter: 11 | ihave do this work but not work any other solution frends 1. Flash Combination 2. Put this code #27663368378#* or *#33725327# choose Setting --- System --- Nv Rebuild --- All 3. Make Reboot 4. Flash From Firmware ( BL + CP + AP ) 5.in csc select From Combination Flash Those Files (Cache + HEROLTE.PIT + META.DATA) |
The Following 3 Users Say Thank You to Tahir shinwari For This Useful Post: |
01-30-2020, 21:25 | #29 (permalink) |
Freak Poster Join Date: Dec 2014 Location: bahrain
Member: 2308999 Status: Offline Sonork: 100.1657583 Thanks Meter: 34 | I FIXED THE PROBLEM IN G935A First flash with G935U FIRMWARE FLASH ENG MODEM FLASH STOCK MODEM (from g935u firmware) PROBLEM FIXED 100% |
