01-30-2016, 18:59 | #1 (permalink) |
Insane Poster Join Date: Feb 2014
Member: 2138059 Status: Offline Thanks Meter: 5 | Modem g925t? Reset EFS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 6. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Operation: Repair Selected model: SM-G925T Software version: 24.1 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 5.1.1 Product code: Phone version: PDA version: G925TUVS3DOJC CSC version: G925TTMB3DOJC CSC country code: USA CSC sales code: TMB HW version: Phone S/N: Modem board: RF cal date: IMEI: Checking Super user right... true Initialization AT RIL... error Done with Samsung Tool PRO v.24.1 Do I need to flash new modem for this to work? |
