03-09-2017, 06:18 | #2 (permalink) |
Freak Poster Join Date: Sep 2011
Member: 1659385 Status: Offline Sonork: 100.1678591 Thanks Meter: 115 | Que firmware tiene? Cual necesitas? Explica mejor, 8 palabras no son suficiente.... Si necesitas soporte en espaņol para Z3x te sugiero que pases por clangsm ese es el soporte en espaņol para Z3x... |
03-20-2017, 22:02 | #3 (permalink) |
Member: 1659385 Status: Offline Sonork: 100.1678591 Thanks Meter: 115 | Translation: What firmware does it have? Which one do you need? Explain better please 8 words are not enough. If you need help in spanish I suggest you stop by clangsm which is the official spanish support for Z3X. |
03-21-2017, 03:01 | #4 (permalink) |
No Life Poster Join Date: May 2016
Member: 2577670 Status: Offline Thanks Meter: 883 | If you need the modem, you can download your original corresponding firmware and extract it to a folder using 7zip software. Then you will find the "Modem.bin". Then you need to convert it into a RAR file. You would then be good to flash your modem through ODIN CP slot. PLEASE CLICK ON THE THANKS BUTTON IF THIS POST WAS HELPFUL |
