09-27-2019, 13:43 | #3 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 430749 Status: Offline Thanks Meter: 24 | UNLOCK INSTRUÇÕES: Unlocking using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-A202F Software version: 37.0 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits.Continue? Sim Waiting ADB device... OK Obtendo informações do celular... Modelo: SM-A202F Android version: 9 PDA version: A202FXXU2ASG1 CSC version: A202FTIM2ASG1 Versão do Celular: A202FXXU2ASF3 Código do Produto: SM-A202FZWDTIM CSC country code: ITALY CSC sales code: TIM Phone SN: RF8M60MAKBE IMEI: 357954105870080 HW version: MP 0.300 RF cal date: 20190606 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2019-07-01 Boot Warranty bit: 0 SIM State: ABSENT,REGIONAL_LOCKED Initialization zTool... OK Running zTool, please wait... OK Obtendo dados do celular... OK Procurando servidor... OK Checking server answer... modem not supported Procurando servidor... OK Checking available files... not found compatible file Try downgrade modem if possible Done with Samsung Tool PRO v.37.0 |
09-27-2019, 13:53 | #4 (permalink) |
Junior Member Join Date: May 2004 Location: Ukraine Age: 50
Member: 67081 Status: Offline Thanks Meter: 1 | I have the same problem with A202F, is there a solution ??? After downgrading the ENG MODEM A202FXXU2ASG1 File By (ANGLE360) Operation: Read Codes via Server Selected model: SM-A202F Software version: 37.0 Checking Login and Password... OK Ballance: 25 crd. You have 25 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A202F Android version: 9 PDA version: A202FXXU2ASG1 CSC version: A202FOXM2ASG1 Phone version: A202FXXU2ASG1 Product code: SM-A202FZKDDBT CSC country code: Germany CSC sales code: DBT Phone SN: RF8M61P7Y5L IMEI: 357953109286251 HW version: MP 0.300 RF cal date: 20190608 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2019-07-01 Boot Warranty bit: 1 SIM State: ABSENT,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... modem not supported Searching server... OK Checking available files... not found compatible file KNOX WARRANTY VOID is 0x1. Phone is not supported Done with Samsung Tool PRO v.37.0 __________________________________________________ _______________________________ After downgrading the EFT modem Operation: Read Codes via Server Selected model: SM-A202F Software version: 37.0 Checking Login and Password... OK Ballance: 25 crd. You have 25 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A202F Android version: 9 PDA version: A202FXXU2ASG1 CSC version: A202FOXM2ASG1 Phone version: A202FXXU2ASH4 Product code: SM-A202FZKDDBT CSC country code: Germany CSC sales code: DBT Phone SN: RF8M61P7Y5L IMEI: 357953109286251 HW version: MP 0.300 RF cal date: 20190608 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2019-07-01 Boot Warranty bit: 1 SIM State: ABSENT,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... modem not supported Searching server... OK Checking available files... not found compatible file KNOX WARRANTY VOID is 0x1. Phone is not supported Done with Samsung Tool PRO v.37.0 |
09-30-2019, 16:05 | #7 (permalink) | |
Junior Member Join Date: Dec 2017 Location: IRAN - Tehran
Member: 2786058 Status: Offline Thanks Meter: 4 | Quote:
How to Root your Phone ?! | |
12-19-2019, 17:22 | #10 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,250 | Unlocked in a few minutes.... )) Code: UNLOCK INSTRUCTIONS: To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-A202F Software version: 38.11 Checking Login and Password... OK Ballance: 12 crd. You have 12 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A202F Android version: 9 PDA version: A202FXXU2ASJ3 CSC version: A202FOXM2ASJ1 Phone version: A202FXXU2ASJ1 Product code: SM2A202FZBDXEO CSC country code: Poland CSC sales code: XEO Phone SN: R58xxxxPGX IMEI: 35931xxxx719422 HW version: MP 0.300 RF cal date: 20190821 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2019-10-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 18641795 NET lock: 38638394 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.38.11 |
