06-10-2015, 02:32 | #2 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Morocco
Member: 1668346 Status: Offline Sonork: 100.1648020 Thanks Meter: 101 | CAN YOU HELP ME SIR. IF I HAVE ERROR IN SELECTED BOOT.bin FILE, GIVE ME GOOD boot.bin FILE FOR LG E960. THANK YOU Selected model is:LG E960 Using COMPORT: 160 Connecting to target... QFastDL Ping Success... Sending Loader... OK Waiting for Loader... Detected APRG instance: COM160 , Qualcomm HS-USB QDLoader 9008 (COM160) Connect OK Configuring protocol... OK Loader mode are EMMC. Set security mode off... OK Opening multi image transfer mode... Timeout! Downloading image FAILED |
06-11-2015, 19:20 | #7 (permalink) |
No Life Poster Join Date: Nov 2009 Location: sri lankan
Member: 1167260 Status: Offline Sonork: 100.1604772 Thanks Meter: 167 | first add flash file for korean new phones or add KDZ file convert option, because today i try flash su640 but i cant find compatible flash file in support then i try convert KDZ file but allways error out of memory bellow is new ver of su640 kdz convert it and upload to support V30D_00 |
06-13-2015, 14:26 | #8 (permalink) |
Insane Poster Join Date: Mar 2011
Member: 1545362 Status: Offline Thanks Meter: 8 | Selected model is:LG P705 Using COMPORT: 20 Connecting to target... QFastDL Ping Success... Sending Loader... OK Waiting for Loader... Detected APRG instance: COM20 , Forge HS-USB QDLoader 9008 (COM20) Connect OK Configuring protocol... OK Loader mode are EMMC. Set security mode off... OK Opening multi image transfer mode... Timeout! Downloading image FAILED COM Port Open Error! Using COMPORT: 20 Connecting to target... QFastDL Ping Success... Sending Loader... OK Waiting for Loader... Detected APRG instance: COM20 , Forge HS-USB QDLoader 9008 (COM20) Connect OK Configuring protocol... OK Loader mode are EMMC. Set security mode off... OK Opening multi image transfer mode... Timeout! Downloading image FAILED |
The Following User Says Thank You to maguitodroga For This Useful Post: |
08-06-2015, 23:29 | #10 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: India
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | Quote:
https://salepok.wordpress.com/2015/0...aupun-offline/ | |
08-06-2015, 23:04 | #11 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2440511 Status: Offline Thanks Meter: 0 | D213 cant connect Hi, can anybody explainme how to conenct D213, for unlock? I have Tried every ways to connect (powered on, without batery, Dmode etc) without any results... it says "Connect powered off MTK device to USB cable... You have 20 secs Time out Boot Failed Thanks in advance |
08-09-2015, 03:18 | #13 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | |
The Following User Says Thank You to toninhosantos For This Useful Post: |
08-31-2015, 01:33 | #15 (permalink) |
Junior Member Join Date: Mar 2008
Member: 728309 Status: Offline Thanks Meter: 1 | LG D100G not connected How to connect LG D100G? Always the same error Selected model is:LG D100G Using COMPORT: COM8 Analising USB Configuration... Connect powered off MTK Device to USB cable... You have 20 seconds. Timed OUT... Booting FAIL Using COMPORT: COM8 Analising USB Configuration... Connect powered off MTK Device to USB cable... You have 20 seconds. Timed OUT... Booting FAIL Using COMPORT: COM19 Analising USB Configuration... Connect powered off MTK Device to USB cable... You have 20 seconds. Timed OUT... Booting FAIL Using COMPORT: COM20 Analising USB Configuration... Connect powered off MTK Device to USB cable... You have 20 seconds. Timed OUT... Booting FAIL When I try to select a rom .kdz or .Bin throws the error "External exception EEFFACE" |
