11-25-2018, 19:34 | #1 (permalink) |
Insane Poster Join Date: Aug 2014 Location: egypt
Member: 2232890 Status: Offline Thanks Meter: 9 | SM-J415fn unlock error but it took the credit? [Answered] i have j415fn tried to unlock it took the credit 2 times but server error UNLOCK INSTRUCTIONS: To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-J415FN Software version: 34.3 Checking Login and Password... OK Ballance: 45 crd. You have 45 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J415FN Android version: 8.1.0 PDA version: J415FNXXU1ARIM CSC version: J415FNOXM1ARIM Phone version: J415FNXXU1ARIM Product code: SM-J415FZDGITV CSC country code: ITALY CSC sales code: ITV Phone SN: R58KA5GV7AT IMEI: 352816104428407 HW version: REV0.4A RF cal date: 2018.10.22 Chip name: MSM8917 Modem board: MSM8917 Security patch: 2018-09-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM23 detected Reading data from phone... OK Calculating... OK Searching server... error unknown error Done with Samsung Tool PRO v.34.3 UNLOCK INSTRUCTIONS: To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-J415FN Software version: 34.3 Checking Login and Password... OK Ballance: 40 crd. You have 40 credit(s) left. This operation takes 5 credits.Continue? No Done with Samsung Tool PRO v.34.3 |
03-11-2019, 17:54 | #3 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Here you can read where can be problem: http://forum.gsmhosting.com/vbb/12570835-post2.html |
