Old 03-05-2019, 02:28   #1 (permalink)
Member: 667857
Thanks Meter: 33
Exclamation My z3x lg cant detect any phone [Answered]
LG 2-3G Tool v9.60
supported models: 1570
Reading timeout, check cable
Error Code: ReadInfo,1,1
Elapsed: 2 secs. --> (v9.60)
Old 03-11-2019, 16:25   #2 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 177,678
Originally Posted by hillboy60 View Post
LG 2-3G Tool v9.60
what phone ?
what cable you use?
where you connect cable?
did you follow manual inside software?
The Following User Says Thank You to blang For This Useful Post:
Old 03-14-2019, 11:04   #3 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,402
Hello,
Do you install LG driver?
Do you enable Diag port? please read connections setting after select model.
Old 05-18-2019, 13:34   #4 (permalink)
Member: 1167511
Thanks Meter: 2
Help with LG unlocking
i get this when trying to unlock lg H918..lock to tmobile...im using a z3x box
Elapsed: 2 secs. --> (v9.61)
Old 05-18-2019, 15:13   #5 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,402
Please read connection section in manual after select phone model. You need enter service code and enable Diag port.
Old 05-18-2019, 15:18   #6 (permalink)
Member: 1167511
Thanks Meter: 2
I dont understand
Sent from my iPhone using Tapatalk
Old 05-18-2019, 15:28   #7 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,402
Originally Posted by addigeneral View Post
I dont understand
After choice model at software software show you manual(help). You need try read Connection section of this manual. Enter service code from manual and enable Diag port.
Old 05-18-2019, 15:54   #8 (permalink)
Member: 1167511
Thanks Meter: 2
Yes i did that still got same result
Old 05-18-2019, 16:31   #9 (permalink)
Member: 1167511
Thanks Meter: 2
Originally Posted by blang View Post
what phone ?
what cable you use?
Lg v20 (981) lock to tmobile, plug to motherboard straight...usb c cable
Old 05-19-2019, 19:20   #10 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,402
Please send team viewer id and pass to me in PM. I check your problem.
Old 05-19-2019, 20:01   #11 (permalink)
Member: 1167511
Thanks Meter: 2
Okay thanks will do
The Following User Says Thank You to addigeneral For This Useful Post:
Old 05-28-2019, 18:24   #12 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,402
Fixed. User can't enable diag port.
Page generated in 0.32410 seconds with 7 queries
