N7000 BLANK IMEI / Phone unknown fix with how-to 4 Attachment(s) As title said, I received N7000 Galaxy Note, with BLANK imei, no signal bars, insert sim card with sim inserted. As many thinks, this is NOT just software issue. First, this is not fix for imei 0000449xxxx (which is software repairable), but at the end, there are backed up EFS files, which can be used for this, too. so, lets get on it : - Disassemble the phone (consult youtube if don't know how) - Take the mainboard off, disconnect all cables gently, remove it from cover - Check attached pictures, remove needed RF Shield covers - Clean the mainboard with isopropyle alcohol, and let it dry for couple minutes - Add some flux to marked regions, and GENTLY, I said GENTLY, reflow it with hot air, for no more than 20 seconds, each marked part - Let it chill down, pack it back to phone cover At this stage ... you should have signal bars back, and imei should be default, 0000049xxxxxx .... time for fixing it with some tools + Z3x Box - Download EFS Backup Pro HERE - Download clean EFS HERE - Put downloaded OK_____GT-N7000_201334_234410.tar.gz archive in EFS Backup folder /EFSProBackup - If you didn't do it before, root the phone, BUSYBox needs to be installed in phone, enable USB debugging - Start EFS Backup sw, let it detect the phone, - Go to RESTORE tab, under restore options - FORMAT EFS, do it - Select backup, check left side, tick EFS and PARAMS, do RESTORE - Reboot phone after done now it's time to finally fix it with one and only Z3x : - Phone powered on, usb debugging enabled - Select N7000 as model, prepare c3300k cable as well, connect to box - In software press read info, phone via usb, must read info - Under 'Repair' options, tick COM port, press repair, USB cable still IN - Don't tick "efs repair", just put IMEI, #and S/N, Bluetooth mac if needed# - After it do first part #write imei# it wil lreboot the phone - Immediately put c3300k COM cable in phone and wait, must be done with success Operation Log : Code: Selected model: N7000 - You should now have fixed imei, with all working ! note: I did it on random ICS 4.0.3 version, process should not be version-dependant check attached pictures for all needed operation info ... and, guys ... don't trust that everything is "software issue" like some other people/teams says ;) best regards to Blang for moral / technical support, and of course, BEST Samsung tool on the market - Z3x Box ! Alex. |
Svaka cast brate... good jop broooo |
bhavik efs backup folder not creat where place this 2 filles efs.img & param.fls not select this file before restore |
tested thanks for good post Br, |
Can someone please suggest how to perform below mentioned two steps..thanks 1. Put downloaded OK_____GT-N7000_201334_234410.tar.gz archive in EFS Backup folder /EFSProBackup 2. If you didn't do it before, root the phone, BUSYBox needs to be installed in phone, enable USB debugging Will appreciate if someone can share their knowledge. Thanks |
Extra bruka haos tebra kobra excellent job |
same problem , with BLANK imei, no signal bars, insert sim card with sim inserted , it help'ed me just a reflow . Thanks |
you have clean EFS I9300 I Need this file tnxxxx br, |
bro,after iclick on FORMAT EFS ...its ALERT ME WITH '"can't locate mount point'' and when i press volum up + power+menu i got error E:/valid arguement or E:/cant mount /efs WHAT SHOULD I DO ? THX BRO ! |
will this be applicable to my n7105t? we also tried everything with the software process nothing seems to work. maybe this is my problem as well. |
Do you have a working efs for 5830? |
Selected model: N7000 Selected port: COM30 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM157 Reading phone info... Model: GT-N7000 Country code: DBT Cal date: - Factory SW: N7000DDLB2 Unique number: CVY19FEC31CAA3F Memory phone: - Software version: N7000DDLB2/N7000ODDLA1/N7000DDLB1/N7000DDLB2 IMEI: 004999010640000 Product code: GT-N7000ZBADBT Done with Samsung Tool v.15.2 Selected model: N7000 Selected port: COM30 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-N7000 Android version: 2.3.6 Product code: GT-N7000ZBADBT Phone version: N7000DDLB1 PDA version: N7000DDLB2 CSC version: N7000ODDLA1 IMEI: 004999010640000 Checking Super user right... true Writing EFS to phone... OK Rebooting phone... OK Searching Samsung modem... detected COM157 Waiting while modem will be ready... OK Reading phone info... Model: GT-N7000 Country code: ERA Cal date: - Factory SW: N7000DDLB2 Unique number: CVY19FEC31CAA3F Memory phone: - Software version: N7000DDLB2/N7000ODDLA1/N7000DDLB1/N7000DDLB2 IMEI: 004999010640000 Product code: GT-I9100LKAERA Bypass MSL... OK Repairing IMEI... OK Repair done Reseting... OK Done with Samsung Tool v.15.2 |
I solve in this way , i reflow only 2 ic and second i repair the imei with z3x with last firmware inside 4.1.2 Selected model: N7000 Selected port: Selected port speed: 115200 Reading phone info... Model: GT-N7000 Android version: 4.1.2 Product code: Not Active Phone version: N7000XXLSO PDA version: N7000XXLSZ CSC version: N7000OXALSZ IMEI: 004999010640000 Phone S/N: 00000000000 Checking Super user right... true Reading data from phone... OK Writing data to phone... OK Rebooting phone... OK Searching Samsung modem... detected COM23 Waiting while modem will be ready... OK Reading phone info... Model: GT-N7000 Country code: DBT Cal date: - Factory SW: N7000XXLSZ Unique number: CVY193658536F3F Memory phone: - Software version: N7000XXLSZ/N7000XXLSO/N7000OXALSZ IMEI: 004999010640000 1 R Product code: Bypass MSL... OK Repairing IMEI... OK Repair done Reseting... OK Done with Samsung Tool v.17.1 Selected model: N7000 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-N7000 Android version: 4.1.2 Product code: Not Active Phone version: N7000XXLSO PDA version: N7000XXLSZ CSC version: N7000OXALSZ IMEI: 352167052402030 Phone S/N: 00000000000 |
- Download EFS Backup Pro HERE - Download clean EFS HERE - Put downloaded OK_____GT-N7000_201334_234410.tar.gz archive in EFS Backup folder /EFSProBackup - If you didn't do it before, root the phone, BUSYBox needs to be installed in phone, enable USB debugging - Start EFS Backup sw, let it detect the phone, - Go to RESTORE tab, under restore options - FORMAT EFS, do it - Select backup, check left side, tick EFS and PARAMS, do RESTORE - Reboot phone after done My question is this, Where I can I put this file "OK_____GT-N7000_201334_234410.tar.gz" Ive been trying to search in my computer/program file) but I can't found this folder "EFS Backup folder /EFSProBackup will you please kindly explain clearly thanks |
Thank you 4ur great discussion.. i have tired from searching .. i will try :) |
