Old 03-06-2013, 01:23   #1 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 4,105
Exclamation N7000 BLANK IMEI / Phone unknown fix with how-to
As title said,
I received N7000 Galaxy Note, with BLANK imei, no signal bars,
insert sim card with sim inserted.
As many thinks, this is NOT just software issue.
First, this is not fix for imei 0000449xxxx (which is software repairable),
but at the end, there are backed up EFS files, which can be used for this, too.
so, lets get on it :
- Disassemble the phone (consult youtube if don't know how)
- Take the mainboard off, disconnect all cables gently, remove it from cover
- Check attached pictures, remove needed RF Shield covers
- Clean the mainboard with isopropyle alcohol, and let it dry for couple minutes
- Add some flux to marked regions, and GENTLY, I said GENTLY, reflow it
with hot air, for no more than 20 seconds, each marked part
- Let it chill down, pack it back to phone cover
At this stage ... you should have signal bars back, and imei should be default,
0000049xxxxxx .... time for fixing it with some tools + Z3x Box
- Download EFS Backup Pro HERE
- Download clean EFS HERE
- Put downloaded OK_____GT-N7000_201334_234410.tar.gz archive in EFS Backup folder /EFSProBackup
- If you didn't do it before, root the phone, BUSYBox needs to be installed in phone, enable USB debugging
- Start EFS Backup sw, let it detect the phone,
- Go to RESTORE tab, under restore options - FORMAT EFS, do it
- Select backup, check left side, tick EFS and PARAMS, do RESTORE
- Reboot phone after done
now it's time to finally fix it with one and only Z3x :
- Phone powered on, usb debugging enabled
- Select N7000 as model, prepare c3300k cable as well, connect to box
- In software press read info, phone via usb, must read info
- Under 'Repair' options, tick COM port, press repair, USB cable still IN
- Don't tick "efs repair", just put IMEI, #and S/N, Bluetooth mac if needed#
- After it do first part #write imei# it wil lreboot the phone
- Immediately put c3300k COM cable in phone and wait, must be done with success
Operation Log :
Selected model: N7000
Selected port: COM3 Z3X BOX Serial Port
Selected port speed: 115200
Reading phone info...
Model: GT-N7000
Android version: 4.0.4
Product code: GT-N7000ZBADBT
Phone version: N7000XXLRK
PDA version: N7000XXLRT
CSC version: N7000DBTLRT
IMEI: Unknown
Checking Super user right... true
Reading data from phone... OK
Writing data to phone... OK
Rebooting phone... OK
Checking phone at COM3 OK
Model: GT-N7000
Country code: DBT
Cal date: -
Factory SW: N7000XXLRT
Unique number: CVY190B1B00BC2F
Memory phone: -
Software version:
IMEI:
Product code:
Bypass MSL... OK
Repairing IMEI... OK
Repair done
Reseting... OK
Done with Samsung Tool v.14.0
- Reboot the phone after operation complete
- You should now have fixed imei, with all working !
note: I did it on random ICS 4.0.3 version, process should not be version-dependant
check attached pictures for all needed operation info ...
and, guys ... don't trust that everything is "software issue" like some other people/teams says
best regards to Blang for moral / technical support, and of course,
BEST Samsung tool on the market - Z3x Box !
Alex.
The Following 7 Users Say Thank You to Brka For This Useful Post:
Old 03-20-2013, 21:12   #2 (permalink)
reserve's Avatar
Member: 521
Thanks Meter: 69
Svaka cast brate...
good jop broooo
The Following User Says Thank You to reserve For This Useful Post:
Old 04-13-2013, 09:21   #3 (permalink)
Member: 1864687
Thanks Meter: 19
bhavik
efs backup folder not creat where place this 2 filles efs.img & param.fls not select this file before restore
Old 04-15-2013, 22:41   #4 (permalink)
reserve's Avatar
Member: 521
Thanks Meter: 69
tested thanks for good post
Br,
Old 04-16-2013, 10:19   #5 (permalink)
Member: 1916213
Can someone please suggest how to perform below mentioned two steps..thanks
1. Put downloaded OK_____GT-N7000_201334_234410.tar.gz archive in EFS Backup folder /EFSProBackup
2. If you didn't do it before, root the phone, BUSYBox needs to be installed in phone, enable USB debugging
Will appreciate if someone can share their knowledge. Thanks
Old 04-16-2013, 13:07   #6 (permalink)
eepromyu's Avatar
Member: 73378
Sonork: Eprom
Thanks Meter: 168
Extra bruka haos tebra kobra excellent job
Old 05-16-2013, 23:41   #7 (permalink)
cover_one's Avatar
Member: 97299
Thanks Meter: 35
same problem , with BLANK imei, no signal bars,
insert sim card with sim inserted ,
it help'ed me just a reflow .
Thanks
Old 05-18-2013, 20:29   #8 (permalink)
reserve's Avatar
Member: 521
Thanks Meter: 69
Question
Originally Posted by Brka View Post
As title said,
Operation Log :
Model: GT-N7000
IMEI: Unknown
Model: GT-N7000
Country code: DBT
Cal date: -
Memory phone: -
Software version:
IMEI:
Product code:
Bypass MSL... OK
Repair done
Reseting... OK
Alex.
you have clean EFS I9300
I Need this file tnxxxx
br,
Old 09-02-2013, 07:50   #9 (permalink)
Member: 2016273
bro,after iclick on FORMAT EFS ...its ALERT ME WITH '"can't locate mount point''
and when i press volum up + power+menu i got error
E:/valid arguement
or
E:/cant mount /efs
WHAT SHOULD I DO ? THX BRO !
Old 10-31-2013, 22:01   #10 (permalink)
Member: 2036774
will this be applicable to my n7105t? we also tried everything with the software process nothing seems to work. maybe this is my problem as well.
Old 10-31-2013, 22:11   #11 (permalink)
Member: 1859706
Sonork: 100.1648492
Thanks Meter: 25
Do you have a working efs for 5830?
Old 11-10-2013, 20:48   #12 (permalink)
I_PHONE's Avatar
Member: 1579234
Sonork: Not user
Thanks Meter: 341
Selected port: COM30 Z3X BOX Serial Port
Searching Samsung modem... detected COM157
Model: GT-N7000
Country code: DBT
Cal date: -
Factory SW: N7000DDLB2
Unique number: CVY19FEC31CAA3F
Memory phone: -
Software version: N7000DDLB2/N7000ODDLA1/N7000DDLB1/N7000DDLB2
IMEI: 004999010640000
Done with Samsung Tool v.15.2
Model: GT-N7000
Android version: 2.3.6
Phone version: N7000DDLB1
PDA version: N7000DDLB2
CSC version: N7000ODDLA1
Writing EFS to phone... OK
Waiting while modem will be ready... OK
Model: GT-N7000
Country code: ERA
Cal date: -
Memory phone: -
Product code: GT-I9100LKAERA
Bypass MSL... OK
Repair done
Reseting... OK
The Following User Says Thank You to I_PHONE For This Useful Post:
Old 05-30-2014, 15:31   #13 (permalink)
Member: 231253
Thanks Meter: 3
I solve in this way , i reflow only 2 ic and second i repair the imei with z3x with last firmware inside 4.1.2
Selected port:
Model: GT-N7000
Android version: 4.1.2
Product code: Not Active
Phone version: N7000XXLSO
PDA version: N7000XXLSZ
CSC version: N7000OXALSZ
Phone S/N: 00000000000
Searching Samsung modem... detected COM23
Model: GT-N7000
Country code: DBT
Cal date: -
Factory SW: N7000XXLSZ
Unique number: CVY193658536F3F
Memory phone: -
Software version: N7000XXLSZ/N7000XXLSO/N7000OXALSZ
IMEI: 004999010640000 1 R
Product code:
Bypass MSL... OK
Repair done
Reseting... OK
Done with Samsung Tool v.17.1
Model: GT-N7000
IMEI: 352167052402030
Old 01-10-2015, 18:52   #14 (permalink)
Member: 230765
Thanks Meter: 5
My question is this,
Where I can I put this file "OK_____GT-N7000_201334_234410.tar.gz"
Ive been trying to search in my computer/program file) but I can't found this folder "
will you please kindly explain clearly
thanks
Old 04-26-2015, 09:13   #15 (permalink)
Member: 206206
Thank you 4ur great discussion.. i have tired from searching .. i will try
Page generated in 0.43454 seconds with 8 queries
