N7100 4.3 Root Error Model: GT-N7100 Android version: 4.3 Product code: GT-N7100TADXEF Phone version: N7100XXEMI6 PDA version: N7100XXUEMI6 CSC version: N7100OXAEMI6 IMEI: 004999010640000 Phone S/N: R31C91MFPAH Checking Super user right... false Rooting phone, please wait... error (0104-1) Done with Samsung Tool v.16.8 |
Selected model: N7100 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 115200 Please, allow USB debugging on phone... Reading phone info... Model: GT-N7100 Android version: 4.3 Product code: Not Active Phone version: N7100XXEMI6 PDA version: N7100XXUEMI6 CSC version: N7100OXAEMI6 IMEI: XXXXXXXXXXXXXXX Phone S/N: XXXXXXXXXXX Checking Super user right... false Rooting phone, please wait... error (0104-1) Done with Samsung Tool v.16.8 Done with Samsung Tool v.16.8 |
elected model: N7100 Selected port: Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-N7100 Android version: 4.3 Product code: Not Active Phone version: N7100XXUEMJ5 PDA version: N7100XXUEMJ5 CSC version: N7100OLBEMJ4 IMEI: xxxxxxxxxxxxxx Phone S/N: xxxxxxxxxxxxx Checking Super user right... false Rooting phone, please wait... error (0104-1) Done with Samsung Tool v.16.8 Done with Samsung Tool v.16.8 same here any solution z3x team |
Use VRoot..................:D |
You have to flash with philz_touch_6.02.1-n7100.tar.md5 on Odin 3.09 and then install Root_N7100_By_KS.zip via recovery with microsd. |
Pre-requisites 1. Install USB Driver for Samsung Galaxy Note 2 on the computer. 2. Enable USB Debugging Mode on the phone by navigating to Settings >> Developer Options. 3. Make a backup of all your important data before following the guide. 4. The Galaxy Note 2 should be factory unlocked and not locked to any particular carrier. 5. Ensure the battery of the phone is charged more than 80 percent. 6. The CF-Auto-Root file works only on the Samsung Galaxy Note 2 with model number GT-N7100. Applying this to any incorrect variant might brick the device. Verify the model number of the Galaxy Note 2 by navigating to Settings >> About Phone. File Required 1. CF-Auto-Root for Galaxy Note 2 N7100 (CF-Auto-Root-t03g-t03gxx-gtn7100.zip) 2. Odin 3.07 Steps to Root Galaxy Note 2 N7100 Running on Android 4.3 Jelly Bean Firmware Step 1: Extract CF-Auto-Root and Odin 3.07 files using winrar/7zip/winzip or any other extracting tool. Step 2: Switch off the Galaxy Note 2. Then boot the device into Download Mode by pressing and holding Volume Down, Home and Power buttons together until a construction Android robot icon with a warning triangle appears on screen. Now press the Volume Up button to enter Download Mode. Step 3: Launch Odin on the computer as an Administrator. Step 4: Connect the Galaxy Note 2 to the computer using USB cable while it is in the Download Mode. Wait until Odin detects the device. When the device is connected successfully, the ID: COM box will turn to light blue with the COM port number. Additionally, the successful connected will be indicated by a message saying Added. Note: If the Added message does not appear, then try re-install USB drivers or changing the port on the computer. Step 5: In Odin, click the PDA button and select the CF-Auto-Root-t03g-t03gxx-gtn7100.tar.md5 file. Step 6: Verify that Auto Reboot and F. Reset Time checkboxes are selected in Odin. Also, ensure the Re-Partition option is NOT selected. Step 7: Double-check and click Start button in Odin. The installation process will now begin. Step 8: Once the installation process is completed, your phone will restart and soon you will see a PASS message with green background in the left-most box at the very top of the Odin. You can now unplug the USB cable to disconnect your device from the computer. Samsung Galaxy Note 2 N7100 running on Android 4.3 Jelly Bean firmware is now rooted successfully. You can now install any app that requires root permission. Verify the root status of the device by downloading Root Checker app from Google Play Store. How to Root Galaxy Note 2 N7100 on Android 4.3 Jelly Bean Firmware - Honai of Android |
have you tried vroot on samsung n7100 4.3 |
i used vroot, install 2 app in chinese, in second one its like app manager or loader and shows all app installed and eliminate knox, reset mobile and flash with odin cf-autoroot and run very good only gives warning about knox I accept and can unlock succesfull with z3x. I think i was lucky because didnt know what was doing. b,r |
