01-04-2014, 11:31 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: (United States Of GINGOOG CITY Age: 47
Member: 120328 Status: Offline Thanks Meter: 243 | n7105 4.3 baseband xxuemj9 Selected port: COM13 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179599 Reading security... error access denied Done with Samsung Tool v.16.8 Done with Samsung Tool v.16.8 any sulotion unlock n7105 4.3? i l try downgrade cant donwgrade error from odin.... |
01-05-2014, 15:22 | #5 (permalink) |
No Life Poster Join Date: Feb 2003 Location: africa Age: 54
Member: 22284 Status: Offline Thanks Meter: 81 | dky tel tell me which cable you used what did you setup after typing *#7284# cause mine is failling to connect .I got the fone with null imei. help and give me the pin cable configration |
02-07-2014, 19:48 | #8 (permalink) |
Member: 22284 Status: Offline Thanks Meter: 81 | Mourad 27 can you explain how we may repair and bring the network using which box AND HOW TO CONNECT Last edited by chitawira; 02-07-2014 at 19:55. |
03-17-2014, 08:24 | #10 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 47
Member: 154051 Status: Offline Thanks Meter: 36 | If You want to unlock 4.3 with new security with Z3X and if You get this error: Selected model: N7105 Selected port: COM5 USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179599 Reading security... error access denied Done with Samsung Tool v.17.2 100% tested and working solution: 1. You must to root phone 2. You must to download and flash only modem. I download this modem only N7105XXDLK7_modem from this link [MODEMS] [N7105] CWM Flashable Modem Collection (updated 3rd August 2013) - xda-developers and extract this file 3. After it with Odin You must to flash modem.bin file. Add modem.bin file in MODEM section (NOT in PDA) 4. When You flash it to phone, then: micro-uart cable: a) Phone must be powered on. b) Type *#7284# and choose Modem for UART. c) Type *#9090# and choose DM over UART. d) Connect the phone to UART port. e) Choose correct COM port in port settings f) Press "Unlock" button. 5.You PHONE UNLOCKED 6.Finally You must to flash 4.3 firmware |
