01-18-2014, 10:24 | #1 (permalink) |
Junior Member Join Date: Apr 2012 Location: pacita laguna
Member: 1752010 Status: Offline Sonork: korerek Thanks Meter: 0 | N7105 4.3 unlock Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179599 Reading security... error access denied Done with Samsung Tool v.16.8 Selected model: N7105 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179599 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.16.8 |
03-17-2014, 08:24 | #4 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 47
Member: 154051 Status: Offline Thanks Meter: 36 | If You want to unlock 4.3 with new security with Z3X and if You get this error: Selected model: N7105 Selected port: COM5 USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179599 Reading security... error access denied Done with Samsung Tool v.17.2 100% tested and working solution: 1. You must to root phone 2. You must to download and flash only modem. I download this modem only N7105XXDLK7_modem from this link [MODEMS] [N7105] CWM Flashable Modem Collection (updated 3rd August 2013) - xda-developers and extract this file 3. After it with Odin You must to flash modem.bin file. Add modem.bin file in MODEM section (NOT in PDA) 4. When You flash it to phone, then: micro-uart cable: a) Phone must be powered on. b) Type *#7284# and choose Modem for UART. c) Type *#9090# and choose DM over UART. d) Connect the phone to UART port. e) Choose correct COM port in port settings f) Press "Unlock" button. 5.You PHONE UNLOCKED 6.Finally You must to flash 4.3 firmware |
The Following 5 Users Say Thank You to YOO For This Useful Post: |
03-26-2014, 07:14 | #6 (permalink) |
Member: 154051 Status: Offline Thanks Meter: 36 | Link http://click.xda-developers.com/api/...ort%3Ddownload but You can enter in google search N7105XXDLK7_modem and you must find this file |
04-04-2014, 16:56 | #7 (permalink) | |
Insane Poster Join Date: Jul 2012 Location: paris, France
Member: 1780775 Status: Offline Sonork: 100.1651901 Thanks Meter: 19 | faile too flash modem.bin Quote:
hi as you said i try to flash N7105XXDLK7_modem .bin files with modem option but finally odin shows fail....and i root first with cf ayto root but super su cant start i mean super su does not work .....can you pls tell me if there is any more tricks.........i am badly need to unlock this model with 4.3 | |
04-04-2014, 17:01 | #8 (permalink) |
No Life Poster Join Date: May 2010 Location: Samsung Mobile Philippines
Member: 1300241 Status: Offline Sonork: 100.1626973 Thanks Meter: 356 | solution! w/ knox security unlock done easy and safe Requirements: internet connection. use 5310 usb cable turn on usb debugging 1st dial *#7284# choose MTP+ADB only download kingoroot: Root Android phone, flash custom ROM and manage your Android devices, Rooting Freeware Download - Kingo after root go to PLAYSTORE then download Super SU by chainfire then Open Super SU the message will pop up KNOX SECURITY" Choose DISABLE now ready to unlock your phone! |
04-24-2014, 11:11 | #9 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | Quote:
Code: Selected model: N7105 Selected port: COM20 USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179590 Reading security... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.17.2 Done with Samsung Tool v.17.2 | |
05-04-2014, 13:05 | #10 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: algeria
Member: 206173 Status: Offline Thanks Meter: 169 | Quote:
The Following User Says Thank You to yahia ali For This Useful Post: |
05-13-2014, 10:57 | #11 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Lagos, Nigeria
Member: 152547 Status: Offline Sonork: 100.1586021 Thanks Meter: 143 | N7105 4.3 unlocked by z3x Selected model: N7105 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179590 Reading security... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.17.2 Done with Samsung Tool v.17.2 |
