01-11-2014, 17:33 | #1 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Classified
Member: 1280253 Status: Offline Thanks Meter: 142 | N7105 - Note 2 Unlock problem - error access denied following are the logs with Uart Cable Selected model: N7105 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179599 Reading security... error access denied Done with Samsung Tool v.16.8 Selected model: N7105 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179599 Reading security... error access denied Done with Samsung Tool v.16.8 br/manbir |
01-20-2014, 14:08 | #4 (permalink) |
No Life Poster Join Date: Jan 2001 Location: France/Martinica/CPU Age: 45
Member: 3026 Status: Offline Sonork: 100.1602750 Thanks Meter: 102 | have the same problem i finaly do efs repair *#7284# UART /PDA USB /PDA DM+modem+adb *#9090# DM/dun over hs-usb i root the phone (but don't know if is necessery with CF-Auto-Root-t0lte-t0ltexx-gtn7105.tar) Selected model: N7105 Selected port: COM29 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-N7105 Android version: 4.3 Product code: GT-N7105TADBOG Phone version: N7105XXUEMJ9 PDA version: N7105XXUEMK9 CSC version: N7105XEFEMK1 IMEI: 35479205319XXXX Phone S/N: RF1XXXXJGQR Checking Super user right... true Writing data to phone... OK Rebooting phone... OK Checking phone at COM29 OK Reseting... OK Repair done after Selected model: N7105 Selected port: COM29 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Checking phone at COM29 Repairing IMEI... OK Reseting... OK Repair done now phone is unlocked |
01-20-2014, 16:09 | #7 (permalink) |
Member: 3026 Status: Offline Sonork: 100.1602750 Thanks Meter: 102 | for repair 3g connection i redo the process Selected model: N7105 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-N7105 Android version: 4.3 Product code: Not Active Phone version: N7105XXUEMJ9 PDA version: N7105XXUEMK9 CSC version: N7105XEFEMK1 IMEI: 35XXXXXXXX Phone S/N: RFXXXXXXR Checking Super user right... true Writing data to phone... OK Rebooting phone... OK Checking phone at COM7 OK Reseting... OK Repair done Done with Samsung Tool v.16.8 Selected model: N7105 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 115200 Checking phone at COM7 Repairing IMEI... OK Reseting... OK Repair done Done with Samsung Tool v.16.8 NOW PHONEZ IS FULL WORKING WITH 3G CONNECTION |
01-21-2014, 09:19 | #9 (permalink) |
Insane Poster Join Date: Feb 2005 Location: Sydney Age: 42
Member: 117678 Status: Offline Thanks Meter: 4 | and sorry but after 4-5 yrs later of being away from repair scene im having trouble understanding some procedure slangs; as in; DM+modem+adb . What would this be? |
01-22-2014, 12:52 | #11 (permalink) | |
Freak Poster Join Date: Aug 2006 Location: Congo
Member: 332635 Status: Offline Sonork: 100.1648966 Thanks Meter: 54 | Quote:
03-17-2014, 08:23 | #12 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 47
Member: 154051 Status: Offline Thanks Meter: 36 | If You want to unlock 4.3 with new security with Z3X and if You get this error: Selected model: N7105 Selected port: COM5 USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179599 Reading security... error access denied Done with Samsung Tool v.17.2 100% tested and working solution: 1. You must to root phone 2. You must to download and flash only modem. I download this modem only N7105XXDLK7_modem from this link [MODEMS] [N7105] CWM Flashable Modem Collection (updated 3rd August 2013) - xda-developers and extract this file 3. After it with Odin You must to flash modem.bin file. Add modem.bin file in MODEM section (NOT in PDA) 4. When You flash it to phone, then: micro-uart cable: a) Phone must be powered on. b) Type *#7284# and choose Modem for UART. c) Type *#9090# and choose DM over UART. d) Connect the phone to UART port. e) Choose correct COM port in port settings f) Press "Unlock" button. 5.You PHONE UNLOCKED 6.Finally You must to flash 4.3 firmware |
04-08-2014, 19:02 | #14 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Lagos, Nigeria
Member: 1918881 Status: Offline Thanks Meter: 44 | Selected model: N7105 Selected port: COM19 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.17.0 I also tried with latest version.. same problem! pls need a perfect solution for this device GT-N7105 Android 4.3 Thanks! |
04-20-2014, 14:12 | #15 (permalink) | |
Freak Poster Join Date: Feb 2011
Member: 1526706 Status: Offline Sonork: Redlou Thanks Meter: 102 | Quote:
100% tested is OK! Thanks Selected model: N7105 Selected port: COM6 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179590 Reading security... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.17.2 Selected model: N7105 Selected port: COM6 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179590 Reading security... OK Searching server... OK NET lock: 73048518 Sub lock: 00000000 SP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool v.17.2 Last edited by yonax; 04-20-2014 at 14:19. | |
