Old 06-01-2017, 12:16   #1 (permalink)
Member: 2325887
Thanks Meter: 134
Thumbs up SM-N900 imei null [Answered]
BACKUP INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore.
6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore.
7. Press 'Write NV DATA' if you need to restore NV backup.
Operation: Write CERT
Selected model: SM-N900
Software version: 28.2
Checking CERT file... Ok
KEY ID: 0813
Waiting ADB device... Ok
Reading phone info...
Model: SM-N900
Android version: 4.4.2
Product code:
Phone version:
PDA version: N900XXUEOB1
CSC version: N900OJVEOB1
CSC country code: KSA
CSC sales code: KSA
HW version:
Phone SN:
Modem board:
RF cal date:
IMEI:
Checking Super user right... true
Reading NV data... Ok
Checking magic... SSNV not found
Done with Samsung Tool PRO v.28.2
Old 06-01-2017, 18:24   #2 (permalink)
Member: 2528503
Sonork: 1670792
Thanks Meter: 70
n900 imei null
Dear Mahi20015
As you can see in software log phone info
Blank .. if phone info blank baseband is unknown
So first you need to flash your device
With different firmwares untill you get baseband the you can repair imei
Even after flashing if you don't get baseband
That means hardware Emmc issue need to replace or try to repair with Emmc tools
Like easy jtag etc.....!!!!
Till that you get same error with all the professional tools
Hope you got it
Regards : masimobilecare
Sent from my iPhone using Tapatalk
The Following User Says Thank You to masimobilecare For This Useful Post:
Old 06-02-2017, 06:33   #3 (permalink)
Member: 2325887
Thanks Meter: 134
which firmware version is good for repair this problem?
The Following User Says Thank You to mahi20015 For This Useful Post:
Old 06-03-2017, 00:36   #4 (permalink)
Member: 2528503
Sonork: 1670792
Thanks Meter: 70
Better try to update via smart switch once
Old 06-03-2017, 02:17   #5 (permalink)
apologized's Avatar
Member: 1712203
Thanks Meter: 354
or try "wipe efs" "reset efs" "write default efs"
The Following User Says Thank You to apologized For This Useful Post:
Old 06-03-2017, 07:09   #6 (permalink)
Member: 2325887
Thanks Meter: 134
i need repair firmware thankss
Old 10-04-2018, 23:33   #7 (permalink)
waqas317's Avatar
Member: 1147735
Thanks Meter: 156
hardware
its baseband look like
Old 10-04-2018, 23:35   #8 (permalink)
waqas317's Avatar
Member: 1147735
Thanks Meter: 156
[IMG]https://3.bp.********.com/-z3tdNdfmLXw/V5uZj0eu-iI/AAAAAAAAAjI/pKXm6NbJYB0diMcS08rrYn3EY5W7-40HgCLcB/s1600/2_online.jpg[/IMG]
Page generated in 0.16926 seconds with 8 queries
