09-22-2016, 23:07 | #1 (permalink) |
Freak Poster Join Date: Dec 2014 Location: US
Member: 2306078 Status: Offline Sonork: 1660961 Thanks Meter: 19 | N900P can not unlock , help Direct Unlock: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button. Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 5. Select device in ADB settings. 6. Press 'Unlock Domestic' button. Operation: Unlock SPRNT Selected model: SM-N900P Selected port: COM23 SAMSUNG Mobile USB Serial Port Software version: 26.7 Waiting ADB device... OK Reading phone info... Model: SM-N900P Android version: 5.0 Product code: Not Active Phone version: N900PVPUEOK2 PDA version: N900PVPUEOK2 CSC version: N900PSPTEOK2 CSC country code: USA CSC sales code: XAS HW version: N900P.12 Phone S/N: 00000000000 Modem board: MSM8974 RF cal date: 2014.02.20 IMEI: Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.7 BUT phone is still invalid simcard . |
09-22-2016, 23:34 | #2 (permalink) |
Freak Poster Join Date: Jun 2013
Member: 1959450 Status: Offline Thanks Meter: 35 | You need to downgrade the modem now too mj4 and do gcf settings and it'll work The modem will fix invalid sim card error. Gcf will fix signal Sent from my SM-G928P using Tapatalk |
09-23-2016, 08:42 | #7 (permalink) |
No Life Poster Join Date: Aug 2015 Location: usa
Member: 2444830 Status: Offline Thanks Meter: 162 | Here you go, flash in CP slot https://mega.nz/#!1kZ3zJLK!JugiToPFn...A_tAQWfIYyIqlg Sent from my iPhone 7 using Tapatalk |
The Following 3 Users Say Thank You to JT man For This Useful Post: |
10-02-2016, 21:37 | #8 (permalink) | |
No Life Poster Join Date: May 2014 Location: Georgia in Gori Age: 34
Member: 2188828 Status: Offline Sonork: WOW Thanks Meter: 66 | Quote:
Thanks | |
10-02-2016, 21:43 | #10 (permalink) |
Member: 2188828 Status: Offline Sonork: WOW Thanks Meter: 66 | see the post: http://forum.gsmhosting.com/vbb/f453...lp-me-2139558/ |
10-02-2016, 21:45 | #11 (permalink) | |
Member: 2444830 Status: Offline Thanks Meter: 162 | Quote:
Sent from my SM-N930T using Tapatalk | |
