12-04-2014, 02:32 | #1 (permalink) |
Insane Poster Join Date: Jan 2009
Member: 958481 Status: Offline Thanks Meter: 2 | n900v no service Selected port: COM705 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching Samsung modem... not found Done with Samsung Tool v.18.2 Selected model: SM-N900V Selected port: COM705 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM706 Reading phone info... Software version: =1,1 IMEI: Product code: Done with Samsung Tool v.18.2 Selected model: SM-N900V Selected port: COM705 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SM-N900V Android version: 4.4.2 Product code: Not Active Phone version: N900VVRUCNC4 PDA version: N900VVRUCNC4 CSC version: N900VVZWCNC4 IMEI: Phone S/N: 00000000000 Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM705 Detected ID: 00000FF3 (MSM8974) SW Version: M8974A-AAAANAZM-2.0.10047 Reading ESN... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Writing data to phone... OK Rebooting phone... OK Waiting phone... OK Reading QCN file... OK Checking phone at COM705 Detected ID: 00000FF3 (MSM8974) SW Version: M8974A-AAAANAZM-2.0.10047 Checking paths... error Done with Samsung Tool v.18.2 Selected model: SM-N900V Selected port: COM705 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Checking certificate file... OK Searching ADB device... OK Reading phone info... Model: SM-N900V Android version: 4.4.2 Product code: Not Active Phone version: N900VVRUCNC4 PDA version: N900VVRUCNC4 CSC version: N900VVZWCNC4 IMEI: Unknown Phone S/N: 00000000000 Checking Super user right... true Bypass MSL... OK Checking for compatible phone and cert... OK Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool v.18.2 trying to use this on att wrote n900q cert everything went fine but wont get signal |
12-23-2014, 00:39 | #4 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | Download DFS Tool or CDMA Workshop (I use paid version) Connect phone send 16digit password ... and make sure "R-UIM Config" is set to "R-UIM only" Problem solved .... |
The Following User Says Thank You to jusmejose For This Useful Post: |
12-23-2014, 18:22 | #7 (permalink) |
Member: 1081371 Status: Offline Thanks Meter: 720 | Not on my side I never had issues with IMEI Cert not passing ... Only with the G900V yeah I have to match the MEID with the IMEI ... But on the N900V I never had issues with it ... |
03-03-2015, 04:21 | #9 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2297291 Status: Offline Thanks Meter: 0 | Hey guys im having the same problem everything went smoothly, i wrote the n900 cert onto the n900v and it has a clean imei but it wont get service, it says EMERFENCY CALLS ONLY. When i type *#0011# into the phone it says "IMEI CERT: PASS" but it also says "SERVICE: LIMITED" . And when i typed in *#06# the meid is the same as the imei so why is it still not working ?! Please help!!! I wrote the cert with the z3x box. ANY HELP WOULD BE APPRECIATED! Thanks! |
03-03-2015, 10:07 | #10 (permalink) |
Insane Poster Join Date: Jun 2009 Location: philippines
Member: 1057346 Status: Offline Sonork: 1606384 Thanks Meter: 10 | before unlocked read first original qcn and after that unlocked procedure reset efs and write cert n900 if no service write original qcn ..mybe it help sir .. |
