09-16-2015, 05:23 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | N910a unknown bb imei null In forum have posted 2 solutins http://forum.gsmhosting.com/vbb/f453...-file-1971658/ http://forum.gsmhosting.com/vbb/f684...-step-1961415/ but its not warke at me becouse after firmware in this file N910AUCU1COC4 phone begen show app update and after 12% began restart.Phone swich on only by this file N910AUCU1BNK3 and other 4.4.4 version too but with 5.0.1 version not wark any solution please THANKS |
The Following User Says Thank You to TUN10 For This Useful Post: |
09-17-2015, 02:42 | #5 (permalink) |
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | Hello think this time supportes or mr blanq will geve me answare I have repaiar my phone bb and imei and now want write qcn fore NETWARK but z3x geve me this error BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Choose diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write QCN Selected model: SM-N910A Selected port: COM6 NsPro Port Software version: 22.6 Reading QCN file... OK Reading ID... error No answer from phone Done with Samsung Tool PRO v.22.6 who qan help me THANKS |
09-17-2015, 11:16 | #6 (permalink) |
Freak Poster Join Date: May 2013
Member: 1947667 Status: Offline Thanks Meter: 31 | No answer from phone. Reason: Selected port: COM6 NsPro Port <---wrong port! Which tool are you using? Port must be the one that the Device Manager windows tells you where the Samsung model is. Start from uploading a picture of Device Manager window when the box and the model, are connected to PC. After you select the correct port, phone will answer something |
09-17-2015, 11:23 | #7 (permalink) | |
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | Quote:
but solutions show by usb. | |
09-17-2015, 17:25 | #8 (permalink) | |
BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Choose diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write QCN Selected model: SM-N910A Selected port: COM329 SAMSUNG Mobile USB Serial Port Software version: 22.6 Reading QCN file... OK Reading ID... OK Detected ID: 00000FF7 (MDM9x25) SW Version: MPSS.DI.3.0.c5-00300-M9625TAARANAZM-1.7892.2 Checking paths... OK Restoring EFS Backup... OK Restoring NV Items... OK Restoring NV Item SIM1... OK Restoring NV Item SIM2... OK Restoring Provisioning Item Files... OK Restore QCN done Done with Samsung Tool PRO v.22.6 | |
