10-07-2015, 11:04 | #3 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2275079 Status: Offline Thanks Meter: 1 | I personally don't use SPT Box for this type of stuff... Open software .... Select model N9005 Boot phone into download mode! Connect phone in download mode with USB...select your Samsung Modem port Click repair default EFS, it's gonna reboot .... Know you select your SPT BOX derail port . Select your IMEI from Super IMEI .... Connect phone using rj45 cable and dial *#0808# and select DM+MODEM+ADB ... And select Factory Mode and phone is gonna factory reset ..... Final set up the phone to home screen .... Turn off phone and connect rj45 cable, phone is going to turn on automatic, and dial *#7284# and select modem over UART and dial again *#0808# and select DM+MODEM+ADB .... Select your SPT Box serial port ... Select model N900t and hit repair 3G network let it finish ... And your done . |
10-08-2015, 10:26 | #4 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Italiaf Age: 65
Member: 135097 Status: Offline Thanks Meter: 22 | hi Blang, my the problem is this: REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 5. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Operation: Write CERT Selected model: SM-N910C Software version: 22.7 Checking certificate file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 5.0.1 Product code: Phone version: N910CXXU1BOE3 PDA version: N910CXXU1BOE3 CSC version: N910COXA1BOE3 CSC country code: Poland CSC sales code: XEO HW version: Phone S/N: RF8G20S33MY Modem board: DB7450R RF cal date: 1234.56.78 IMEI: Checking Super user right... true Reading nv data... OK Analisis NV data... error Security damaged Done with Samsung Tool PRO v.22.7 |
02-01-2016, 15:01 | #9 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 301829 Status: Offline Thanks Meter: 14 | aoa n910c security damge solution 10000000& pure just solution is write cert with octopus and wait few mints phone restart and then conect to uart cable and the box write imei done this is 100 % solution i m trying and 100 % suecces plz dear its not a fake solution its a orignal solution |
02-01-2016, 15:09 | #10 (permalink) |
Member: 301829 Status: Offline Thanks Meter: 14 | INFO : 2/1/2016 6:43:13 PM > Platform: Samsung Android INFO : 2/1/2016 6:43:13 PM > Selected port: COM3 INFO : 2/1/2016 6:43:13 PM > Selected model: SM-N910C INFO : 2/1/2016 6:43:30 PM > Selected file: C:\Users\Downloads\Cert-sm-n910c_imei.cert INFO : 2/1/2016 6:43:33 PM > Detected phone model: SM-N910C INFO : 2/1/2016 6:43:33 PM > Firmware compiled date: Fri Feb 6 22:39:46 KST 2015 INFO : 2/1/2016 6:43:33 PM > PDA version: N910CXXU1BOB4 INFO : 2/1/2016 6:43:34 PM > CSC version: N910COXA1BOB4 INFO : 2/1/2016 6:43:34 PM > SW version: N910CXXU1BOB4 INFO : 2/1/2016 6:43:36 PM > Phone SN: 00000000000 INFO : 2/1/2016 6:43:36 PM > Android version: 5.0.1 (LRX22C) INFO : 2/1/2016 6:43:36 PM > Checking Root: INFO : 2/1/2016 6:43:37 PM > Phone is Rooted. INFO : 2/1/2016 6:43:37 PM > Reading security backup, please wait... WARN : 2/1/2016 6:44:20 PM > Phone will restart now. Please don't disconnect cable! WARN : 2/1/2016 6:47:14 PM > Perform the following steps: WARN : 2/1/2016 6:47:14 PM > 1. Connect phone via UART cable to the Box. WARN : 2/1/2016 6:47:14 PM > 2. Note: phone screen must be active INFO : 2/1/2016 6:47:14 PM > Connecting to phone, please wait... INFO : 2/1/2016 6:47:19 PM > Found phone on COM221 INFO : 2/1/2016 6:47:19 PM > Phone connected successfully INFO : 2/1/2016 6:47:19 PM > Checking Certificate file... INFO : 2/1/2016 6:47:19 PM > Certificate file successfully checked INFO : 2/1/2016 6:47:19 PM > Writing new phone IMEI... INFO : 2/1/2016 6:47:38 PM > Checking certificate compatibility... INFO : 2/1/2016 6:47:38 PM > Certificate is compatible INFO : 2/1/2016 6:47:38 PM > Writing Certificate... INFO : 2/1/2016 6:47:45 PM > Certificate has been written successfully INFO : 2/1/2016 6:47:45 PM > Please, restart the phone to apply changes i m try and also post loge file its orignal not a fake |
01-30-2017, 07:32 | #11 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1387282 Status: Offline Sonork: 5440 Thanks Meter: 1 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-N910C Software version: 27.7 Waiting ADB device... Ok Reading phone info... Model: SM-N910C Android version: 5.1.1 Product code: Phone version: N910CXXU1COH4 PDA version: N910CXXU1COH4 CSC version: N910COXA1COH4 CSC country code: Poland CSC sales code: XEO HW version: Phone SN: 00000000000 Modem board: DB7450R RF cal date: 1234.56.78 IMEI: Checking Super user right... true Reading NV data... Ok Analyzing NV data... Ok error Security damaged Done with Samsung Tool PRO v.27.7 |
01-30-2019, 21:58 | #12 (permalink) | |
Major Poster Join Date: Apr 2016 Location: Venezuela
Member: 2557738 Status: Offline Thanks Meter: 25 | solution 100% done Quote:
just select MODEL N900A write cert of N910C Operation: Write CERT Selected model: SM-N900A Software version: 34.8 Checking CERT file... Listo KEY ID: 0065 Waiting ADB device... Listo Leyendo información del teléfono ... Modelo: SM-N910C Android version: 5.0.1 PDA version: N910CXXU1BOG1 CSC version: N910CUWA1BOG1 Versión del telefono: N910CXXU1BOF1 Código del Producto: CSC country code: PERU CSC sales code: PET Phone SN: IMEI: HW version: RF cal date: 1234.56.78 Chip name: EXYNOS5433 Modem board: DB7450R Boot Warranty bit: 1 Incorrect model selected. This may damage your phone. Continue? Yes Writing AT RIL... Listo Initialization AT RIL... Listo Bypass MSL... Listo Checking for compatible phone and cert... Listo Phone KEY ID: 0065 Writing CERT... Listo Checking CERT status... Listo Reiniciando teléfono ... Listo Done with Samsung Tool PRO v.34.8 | |
