12-08-2016, 18:06 | #17 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Egypt Age: 38
Member: 534871 Status: Offline Sonork: 100.1607626 Thanks Meter: 302 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-N900A Selected port: COM10 Z3X BOX Serial Port Software version: 27.4 Checking CERT file... Ok KEY ID: 0065 Waiting ADB device... Ok Reading phone info... Model: SM-N910C Android version: 6.0.1 Product code: Phone version: N910CXXU1DPC1 PDA version: N910CXXU2DPF6 CSC version: N910COJV2DPF1 CSC country code: UAE CSC sales code: XSG HW version: Phone SN: RF8G92HE80B Modem board: DB7450R RF cal date: 1234.56.78 IMEI: Incorrect model selected. This may damage your phone. Continue? Yes Writing AT RIL... Ok Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... Ok Bypass MSL... Ok Checking for compatible phone and cert... Ok Phone KEY ID: 0065 Writing CERT... Ok Checking CERT status... Ok Rebooting phone... Ok Done with Samsung Tool PRO v.27.4 |
12-10-2016, 09:40 | #18 (permalink) |
Crazy Poster Join Date: Apr 2014 Location: Takia Azamgarh
Member: 2170271 Status: Offline Thanks Meter: 24 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-N900A Selected port: COM1 Nuvoton Communications Port Software version: 27.4.2 Checking CERT file... Ok KEY ID: 0065 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-N910C Android version: 5.0.1 Product code: Phone version: N910CXXU1BOE1 PDA version: N910CXXU1BOE1 CSC version: N910COJV1BOE1 CSC country code: KSA CSC sales code: KSA HW version: Phone SN: RF8G20CY1JF Modem board: DB7450R RF cal date: 1234.56.78 IMEI: Writing AT RIL... Ok Initialization AT RIL... Ok Bypass MSL... Ok Checking for compatible phone and cert... Ok Phone KEY ID: 0065 Writing CERT... Ok Checking CERT status... Ok Rebooting phone... Ok Done with Samsung Tool PRO v.27.4.2 |
01-15-2017, 19:52 | #20 (permalink) |
Freak Poster Join Date: Dec 2015 Location: Bangladesh Age: 36
Member: 2497406 Status: Offline Sonork: 100.1672478 Thanks Meter: 50 | pls halp me any bro.write cert pls halp BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-N910C Software version: 27.7 Checking CERT file... Ok KEY ID: 0065 Waiting ADB device... Ok Reading phone info... Model: SM-N910C Android version: 6.0.1 Product code: Phone version: PDA version: N910CXXS2DPK1 CSC version: N910COXE2DPI2 CSC country code: Central Asia CSC sales code: CAC HW version: Phone SN: Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Analyzing NV data... error Security damaged Done with Samsung Tool PRO v.27.7 |
06-26-2017, 17:37 | #26 (permalink) |
Freak Poster Join Date: Aug 2014 Location: Enugu
Member: 2241097 Status: Offline Thanks Meter: 17 | A Big Thanks To The Owner Of This Thread...It Worked Like Magic Checking CERT file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 5.0.1 Product code: Phone version: N910CXXU1COJ5 PDA version: N910CXXU1BOE1 CSC version: N910COJV1BOE1 CSC country code: South Africa CSC sales code: XFM HW version: Phone SN: 00000000000 Modem board: DB7450R RF cal date: 1234.56.78 IMEI: Writing AT RIL... OK Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0065 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.28.2 |
08-20-2017, 10:24 | #30 (permalink) |
Junior Member Join Date: Jun 2016 Location: Abidjan,ivory coast
Member: 2592013 Status: Offline Sonork: 100.1677206 Thanks Meter: 0 | GOOD Opération:Write CERT Modèle sélectionné:SM-N900A Version du logiciel:29.1 Vérification du dossier CERT... Ok KEY ID: 0065 En attendant le périphériqueADB... Ok Lecture d'information du telephone... Modèle: SM-N910C Android version: 6.0.1 Code du produit: Version du telephone: N910CXXU1DPE4 PDA version: N910CXXS2DQA5 CSC version: N910CCOE2DQA1 SCC code de pays: COLOMBIA CSC code de vente: COE HW version: Téléphones SN: R28G32E5Y9J Prise modem: DB7450R Security patch: 2017-01-01 RF cal date: 1234.56.78 IMEI: RédactionAT RIL... Ok InitialisationAT RIL... racine requis Vérification de droit de super utilisateur... vrai InitialisationAT RIL... Ok Contourne MSL... Ok Vérification pour le téléphone et cert compatible... Ok Téléphones KEY ID: 0065 RédactionCERT... Ok Vérification de l'étatCERT... Ok Redémarrage téléphone... Ok Fait avecSamsung Tool PRO v.29.1 |
