08-28-2017, 11:52 | #31 (permalink) |
Freak Poster Join Date: Jan 2017
Member: 2673061 Status: Offline Thanks Meter: 82 | Selected model: SM-N910C Software version: 29.1 Checking CERT file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 6.0.1 Product code: Phone version: N910CXXU1DPC1 PDA version: N910CXXU2DPCB CSC version: N910COXE2DPC1 CSC country code: Central Asia CSC sales code: CAC HW version: Phone SN: 00000000000 Modem board: DB7450R Security patch: 2016-04-02 RF cal date: 1234.56.78 IMEI: Checking Super user right... true Reading NV data... OK Analyzing NV data... error Security damaged Done with Samsung Tool PRO v.29.1 HELP plz i change cert is error solution plz bro now |
11-07-2017, 02:16 | #34 (permalink) |
Junior Member Join Date: Sep 2015 Location: Quintana Roo
Member: 2460513 Status: Offline Thanks Meter: 37 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-N900A Software version: 29.6 Checking CERT file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 6.0.1 Product code: Phone version: N910CXXU1DPE4 PDA version: N910CXXS2DQHK CSC version: N910CTCE2DPH1 CSC country code: MEXICO CSC sales code: TCE HW version: Phone SN: 00000000000 Modem board: DB7450R Security patch: 2017-08-01 RF cal date: 1234.56.78 IMEI: 350050500009692 Writing AT RIL... OK Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0065 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.29.6 Thanks |
11-15-2017, 12:02 | #35 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | Quote:
its work like a magic...................... | |
05-16-2018, 08:57 | #45 (permalink) |
Junior Member Join Date: Jul 2006
Member: 318860 Status: Offline Thanks Meter: 1 | N910C security damage REAL SOLUTION 100% Hi guys, after try a lot of "solutions" finally found the right one who really works... if you got the N910c with SECURITY DAMAGE problem, and cant write cert because of that just select MODEL N900A write cert of N910C thanks for this idea tested |
The Following User Says Thank You to nulada For This Useful Post: |
