05-23-2017, 15:07 | #1 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2278041 Status: Offline Thanks Meter: 1 | N910F Unlock failed Tried to unlock Samsung Galaxy Note 4 today running on 6.0.1 security patch from 01 April 2017, Baseband N910FXXS1DQA2, Build Number: MMB29M.N910FXXS1DQD3 Here is log from Z3X: Reading phone info... Reading IMEI... Ok IMEI: Unlocking... error (0) Done with Samsung Tool PRO v.28. Can you downgrade modem and if yes could it damage Imei? Wouldn't want to flash it with different Cert and change Imei |
05-23-2017, 16:09 | #2 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
1. CF-Auto-Root-trlte-trltexx-smn910f.zip Then opens supersu deactivates knox 2. Turn on usb debugging Then activate adb-modem + mb 3. Use this modem: CP_N910FXXU1COJ3.tar.md5 https://www.androidfilehost.com/?fid=24269982087021403 Fash with Odin in CP 4. Then select the generated ports and give them a unlock | |
05-23-2017, 16:52 | #3 (permalink) |
Member: 2278041 Status: Offline Thanks Meter: 1 | Thank you I was worried I would loose original Imei if I would try to dongrade the modem, unlocked ok now and Imei is ok. |
The Following User Says Thank You to tomaszpin For This Useful Post: |
