03-16-2016, 16:51 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | N910H anlysis nv data error-security damaged-did repair efs-still same error tried to write certificate-error as security damged-so i did repair efs-logs as below Operation: Reset EFS Selected model: SM-N910H Software version: 24.7 Waiting ADB device... OK Reading phone info... Model: SM-N910H Android version: 5.0.1 Product code: Phone version: N910HXXU1BOE1 PDA version: N910HXXU1BOE1 CSC version: N910HOJV1BOE1 CSC country code: GHANA CSC sales code: ACR HW version: Phone S/N: 00000000000 Modem board: DB7450R RF cal date: 1234.56.78 IMEI: Checking Super user right... true Backuping EFS... OK Reseting EFS... OK Rebooting phone... OK Done with Samsung Tool PRO v.24.7 then again tried write certificate-error as below Checking certificate file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N910H Android version: 5.0.1 Product code: Phone version: N910HXXU1BOE1 PDA version: N910HXXU1BOE1 CSC version: N910HOJV1BOE1 CSC country code: GHANA CSC sales code: ACR HW version: Phone S/N: Modem board: DB7450R RF cal date: 1234.56.78 IMEI: Checking Super user right... true Reading nv data... OK Analisis NV data... error Security damaged Done with Samsung Tool PRO v.24.7 what i do as a next step |
04-27-2016, 10:28 | #2 (permalink) |
Freak Poster Join Date: Apr 2016 Location: azaz
Member: 2560889 Status: Offline Thanks Meter: 106 | if youhave octopus box then your problem will be solved just try to write N910C cert via octopus and follow software instructions after finish box will tell you that cert is not compatible with phone (do not worry every thing is ok) now just go back to z3x box and write your cert file or any N910C cert file and it will be written do not forget to press thanks |
06-30-2016, 22:13 | #3 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2586461 Status: Offline Thanks Meter: 3 | Checking certificate file... OK KEY ID: 0772 در انتظار دستگاه adb... OK درحال خواندن اطلاعات گوشی... مدل: SM-N910H نسخه ی اندروید: 6.0.1 کد دستگاه: نسخه گوشی: N910HXXU1DPC1 نسخه ی PDA: N910HXXU2DPE2 نسخه ی CSC: N910HOJV2DPE1 CSC country code: Iraq CSC sales code: MID HW version: شماره سریال گوشی: Modem board: DB7450R RF cal date: 1234.56.78 شماره IMEI: درحال چک کردن روت بودن گوشی... درست در حال خواند اطلاعات nv... OK Analisis NV data... error Security damaged Done with Samsung Tool PRO v.25.8 |
09-02-2016, 08:54 | #4 (permalink) | |
Freak Poster Join Date: Jan 2015 Location: Malawi
Member: 2330405 Status: Offline Sonork: 100.1661964 Thanks Meter: 37 | Quote:
11-01-2016, 00:19 | #6 (permalink) |
No Life Poster Join Date: May 2007
Member: 512970 Status: Offline Sonork: 100.1584185 Thanks Meter: 134 | YES IF U CHANGE MODEL TO N900A BE NOT CONTROL SECURTY AND ERASE EFS CORECTLY AND WIRITE STRRET CERTIFICAT FILE BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-N900A Selected port: Software version: 27.0 Checking CERT file... ok KEY ID: 0065 Waiting ADB device... ok Reading phone info... Model: SM-N910H Android version: 5.1.1 Product code: Phone version: N910HXXU1COJ2 PDA version: N910HXXS2CPC2 CSC version: N910HOJV2COJ1 CSC country code: Iraq CSC sales code: MID HW version: Phone SN: 00000000000 Modem board: DB7450R RF cal date: 1234.56.78 IMEI: Writing AT RIL... ok Initialization AT RIL... ok Bypass MSL... ok Checking for compatible phone and cert... ok Phone KEY ID: 0065 Writing CERT... ok Checking CERT status... ok Rebooting phone... ok BR ..::MPOGSM::.. |
The Following 4 Users Say Thank You to mounir0020 For This Useful Post: |
11-05-2018, 11:19 | #8 (permalink) |
Junior Member Join Date: Jan 2018 Location: afghanistan
Member: 2796143 Status: Offline Sonork: 100.1679754 Thanks Meter: 4 | Checking CERT file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N910H Android version: 5.1.1 PDA version: N910HXXU2COJ4 CSC version: N910HOJV2COJ1 Phone version: N910HXXU1COJ2 Product code: CSC country code: Kenya CSC sales code: AFR Phone SN: IMEI: 350050500009692 HW version: RF cal date: 1234.56.78 Chip name: EXYNOS5433 Modem board: DB7450R Security patch: 2015-11-01 Boot Warranty bit: 1 Incorrect model selected. This may damage your phone. Continue? Yes Writing AT RIL... OK Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0065 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.33.8 Done Now |
The Following User Says Thank You to ByCo GSM For This Useful Post: |
