06-13-2015, 07:03 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: U.S.A.
Member: 285890 Status: Offline Thanks Meter: 72 | N910T Android 5.0.1 imei Repair without Downgrade. 1/ Flash NK4 Modem from here http://www.mediafire.com/download/77...2bft/modem.bin 2/ Reset MSL and unlock ONLY with Z3X. 3/ Flash OD6 Modem from here http://www.mediafire.com/download/6p...a3c4/modem.bin 4/ Now write your cert. You should be OK by Now. P.S Flash Modem using Odin, and select CP if you are using Odin 3, or select Phone if you are using Odin 1.85. P.S Don't rename Modem.bin, otherwise Odin will fail flashing. |
The Following 4 Users Say Thank You to meido one For This Useful Post: |
06-13-2015, 08:07 | #2 (permalink) |
Member: 285890 Status: Offline Thanks Meter: 72 | i have done it today, i am away from my office now, but i will post the log soon. by the way, have you RESET MSL while Modem on NK4? Last edited by meido one; 06-13-2015 at 08:12. |
06-13-2015, 21:29 | #6 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Why not just write the CERT while the modem is downgraded... then after everything is done write the OD6 modem back? Is there something I'm missing about using that scenario? |
The Following User Says Thank You to ecs87 For This Useful Post: |
06-14-2015, 21:19 | #10 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
06-14-2015, 21:24 | #12 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | I think the problem is that on Lollipop for this model the MSL isnt being reset, or its looking in the wrong spot for the MSL address. Im sorry for the vague response, im not around phones nearly as much as i used to be. |
06-14-2015, 22:10 | #13 (permalink) | |
Member: 285890 Status: Offline Thanks Meter: 72 | Quote:
@Blang the only option to reset MSL is downgrade to 4.4.4. by the way MSL Reset works on N910A on 5.0.1 without downgrade. | |
06-15-2015, 04:08 | #14 (permalink) | |
06-26-2015, 04:26 | #15 (permalink) |
Insane Poster Join Date: Nov 2013
Member: 2061249 Status: Offline Thanks Meter: 18 | i get to writing cert and it fails.... i've downgraded and done all that it says to reset MSL first.. but i've done that it resets if I change the modem.... how do I stop that...???.. this is too annoying Lol |
