11-26-2014, 05:46 | #1 (permalink) |
Insane Poster Join Date: Mar 2014 Location: LOUISIANA Age: 42
Member: 2140825 Status: Offline Thanks Meter: 5 | n910t efs wipe not working if anyone has any suggestions or ideas on this i would like to hear every ones input Last edited by smsprepaids; 11-26-2014 at 05:53. |
The Following User Says Thank You to smsprepaids For This Useful Post: |
11-26-2014, 14:00 | #2 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Please don't go around wiping any ole partitions. One of them may be your bootloader (ask me how I know...lol) and then you'll have an even bigger problem on your hands: a hard brick. With that in mind you must know what you're looking for. Most likely it's 3 EFS data partitions as it's been for MOST phones. They are modemst1, modemst2, and FSG. Wipe these either through adb with root or download mode, and your efs is set to default. Not too sure how much experience you have with CDMA phones but some of them don't even have a modemst1, modemst2 or FSG partition(s). Instead they have m9kefs partitions. I was googling N910T partitions to get an idea of where to look on the N915T and saw that they might've went back to an old standard of naming EFS partitions (the m9kefs naming...or something along those lines). If you're trying to do it manually through adb or Heimdall (download mode) at least now you have direction instead of shooting at partitions in the dark. |
11-26-2014, 15:16 | #3 (permalink) | |
Junior Member Join Date: Oct 2010
Member: 1408878 Status: Offline Thanks Meter: 16 | Quote:
but but my attemps to wipe them have not wiped imei | |
The Following 3 Users Say Thank You to oakieville For This Useful Post: |
11-26-2014, 17:09 | #5 (permalink) | |
Member: 2076039 Status: Offline Thanks Meter: 648 | Quote:
The Following User Says Thank You to ecs87 For This Useful Post: |
11-27-2014, 19:22 | #7 (permalink) |
Major Poster Join Date: Nov 2014
Member: 2288583 Status: Offline Thanks Meter: 10 | I wont hold out any longer lol Happy thanksgiving guys ive been doing note 4 for about a month ready for the note 4 knowledge you only need to wipe 2 partitions mdm1m9kefs1 & mdm1m9kefs2 but you guys tried to wipe this and original imei is still there correct?? HERES SOLUTION its cf autoroot that cause the problem it flashed a modified cache and recovery in your firmware you need to find corresponding firmware of phone your using turn the md5 odin file into a zip and extract the recovery img and cache file and create a odin flashable of the stock system recovery and cache I have created file for n910t already if its needed now you have all original partitions and rooted system now try to wipe efs it will be SUCCESSFULL when the ***** on the other foot I expect in return lol EFS WONT WIPE ON NOTE 4 WITH MODOFIED PARTITONS |
The Following 4 Users Say Thank You to johndoe0626 For This Useful Post: |
11-27-2014, 20:17 | #10 (permalink) | |
11-28-2014, 06:30 | #12 (permalink) |
Member: 2288583 Status: Offline Thanks Meter: 10 | Last important thing Sorry in efs mdm1m9kefs1 mdm1m9kefs2 mdm1m9kefs3 & mdm1m9kefsfc needs to be wiped if your doing it manuaully I repeat do not wipe the efs /dev/block/mmcblk0p13 if you wipe this partition the fingerprint scanner and heartrate monitor will no longer function |
11-28-2014, 06:58 | #13 (permalink) |
Member: 1408878 Status: Offline Thanks Meter: 16 | ok thanks for clarifying i do need to wipe all 4 again after restoring recovery and cache partitions due to cf. also i never wipe actual efs partition that has many bad affects |
11-28-2014, 18:09 | #14 (permalink) |
Member: 2288583 Status: Offline Thanks Meter: 10 | exactly wipe all 4 after restoring let me know your success . Now we need someone to show us the easy way to repair these wipe through download mode & write cert thru uart I know someone who does n910a repair he doe it in about 2 min and thats his method no rooting no finding firmwares. no bs |
11-28-2014, 18:22 | #15 (permalink) | |
