08-15-2017, 19:17 | #1 (permalink) |
Junior Member Join Date: Jul 2017 Age: 37
Member: 2739768 Status: Offline Thanks Meter: 4 | N910t FRP/EE/reactivation? No option in Samsung pro. Sent from my LG-M153 using Tapatalk |
The Following User Says Thank You to 8bitDroid For This Useful Post: |
01-28-2018, 16:27 | #4 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2016
Member: 2532914 Status: Offline Thanks Meter: 1,154 | by cloning he means buy a cheap used device like an s4 (pre cert phone). so you can put whatever imei on it. then write the imei of the phone you want to remove samsung lock onto your phone. then on your phone create or sign into samsung account. after you do that go to other phone and use that same sign in info to get past samsung login. make sure phone is on a 5.1.1 rom. if you use 6.0.1 you will get processing error. that simple. there are other ways to do it but that is what he meant by cloning method. you can also flash combo to phone then install samsung apk and sign into samsung account while combo rom is installed. then flash a 5.1.1 stock rom back to phone then sign into samsung with same info you used while combo rom was on phone. Last edited by markhaines1985; 01-28-2018 at 16:33. |
