01-17-2016, 09:45 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Age: 37
Member: 161823 Status: Offline Thanks Meter: 71 | N910T unlock but phone silt lock UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC' (ignore it, if it's not available). 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-N910T Selected port: COM22 SAMSUNG Mobile USB Serial Port Software version: 24.1 Reading phone info... Reading IMEI... OK IMEI: 356095065135576 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.24.1 |
11-02-2016, 02:37 | #10 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2643978 Status: Offline Thanks Meter: 0 | i am having the same problem. I was able to unlock a couple of updates ago. Operation: Unlock Selected model: SM-N910T Selected port: COM26 SAMSUNG Mobile USB Serial Port Software version: 26.9 Reading phone info... Reading IMEI... OK IMEI: 354594063419448 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.9 it says it is unlock, but it is not. phone has 5.1.1 any help is apreciated thanks, |
11-02-2016, 02:47 | #11 (permalink) |
Member: 2643978 Status: Offline Thanks Meter: 0 | I just updated and now i am getting error (0) UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC' (ignore it, if it's not available). 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-N910T Selected port: COM26 SAMSUNG Mobile USB Serial Port Software version: 27.0 Reading phone info... Reading IMEI... ok IMEI: 354594063419448 Unlocking... error (0) Done with Samsung Tool PRO v.27.0 same phone has 5.1.1 any help is apreciated thanks, |
11-02-2016, 04:30 | #12 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,053 | Quote:
Br, xerraco | |
