07-25-2015, 18:23 | #1 (permalink) |
Freak Poster Join Date: Aug 2011 Location: New York City
Member: 1637281 Status: Offline Sonork: 100.1657188 Thanks Meter: 95 | N915A Bootloop Thread I have a *#9090# bootloop from instructions on z3x (because they don't update instructions.) I downgraded and it boots, but when i go back to 5X lollipop it bootloops. Help someone. Finger on donation button to whoever can give the real solution. Thanks. |
07-25-2015, 21:07 | #5 (permalink) |
Member: 1637281 Status: Offline Sonork: 100.1657188 Thanks Meter: 95 | yeah I tried that and it won't even boot all the way. it reboots on optimizing apps. I'm pretty sure someone knows how to do it just no one wants to share. |
02-24-2016, 01:52 | #8 (permalink) |
Freak Poster Join Date: May 2006 Location: U.S.A.
Member: 285890 Status: Offline Thanks Meter: 72 | someone post a solution for N910A about same issue, anyway i will give you a hint on how does it work. 1. You need to flash Factory Binary firmware. 2. Root it "hint use kingo root APK" 3. Use command line to wipe the EFS. " you gotta be very quick on wiping. 4. Flash cert. 5. Flash original Firmware. Good luck. |
03-03-2016, 21:10 | #10 (permalink) |
Freak Poster Join Date: May 2006 Location: USA
Member: 280098 Status: Offline Thanks Meter: 62 | Try flashing PIT file first and see how it goes...( TBLTE_USA_ATT PIT FILE) After that flash this file with Odin3_v3.10.7 check mark nand flash erase (ALL_ATT_N915AUCU2COI2 CLICK HERE) Good luck |
