10-08-2016, 11:11 | #1 (permalink) |
Crazy Poster Join Date: Apr 2005 Age: 48
Member: 136882 Status: Offline Thanks Meter: 16 | N920 Bootloader/Modem Downgrade I urgently need help. N920C with latest update (N920CXXU3BPIA_N920COXE3BPI2_N920CXXU3BPH4) The modem has been patched before when it was on OJ5 and after that some idiot made the update through ODIN. My problem now is: Downgrade modem impossible cause bootloader is locked. New modem not supported for patch. TWRP installable, root OK. What can I do to get the modem work again? I am trying since 5 hours but no success. Thx in advance |
10-09-2016, 06:38 | #4 (permalink) |
Member: 136882 Status: Offline Thanks Meter: 16 | Thx for your answer. N920C Note 5. Log irrelevant modem not supported by Z3X. I need solution to downgrade modem to OJ5 or other patchable version. Bootloader locks downgrade each time when I flash with older firmware as the firmware on the phone with sec patch 09/2016. |
10-09-2016, 11:58 | #5 (permalink) |
Member: 136882 Status: Offline Thanks Meter: 16 | For all who have the same prob: I managed to return the phone to the initial state. The problem is as described the new bootloader that blocks downgrades. Long before ee had the same probs with S4 phones whose modem could not be repaired after imei write with box. This time we have the possibility of using the combination firmware. Flashing the firmware allows to repair imei (only repair no patch) so that after writing the original imei to the phone and flashing again with the same firmware on the phone the phone becomes alive again. (*#0011# gives answer OK) Tried to do the same procedure with different imei but no network and status N/A. PM me if you have further questions. |
10-09-2016, 12:05 | #6 (permalink) |
Member: 136882 Status: Offline Thanks Meter: 16 | Procedure to write Orig IMEI to phones with changed/lost IMEI and Network Probs after update. 1. Flash combination firmware 2. Wipe cache and dalvik 3. Developer options-->Enable USB debug 4. Repair imei 5. Reboot (auto reboot does not work) 6. Flash 1:1 firmware before combi firmware 7. Wipe again 8. check IMEI status Ok *#0011# 9. Enjoy network again |
The Following User Says Thank You to 66nakyoz For This Useful Post: |
10-09-2016, 13:11 | #7 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
10-23-2016, 02:52 | #8 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: syria
Member: 205475 Status: Offline Thanks Meter: 179 | thanx Quote:
