10-19-2017, 09:28 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | n9200 cert file write BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-N9200 Software version: 29.5 Checking CERT file... OK KEY ID: 0092 Waiting ADB device... OK Reading phone info... Model: SM-N9200 Android version: 6.0.1 Product code: SM-N9200ZDUTGY Phone version: N9200ZHU3CQD2 PDA version: N9200ZHU3CQD2 CSC version: CSC country code: CSC sales code: HW version: MP0.7ATGY Phone SN: R28H33ZNVNM Modem board: MDM9635M Security patch: 2017-04-01 RF cal date: 2016.03.29 IMEI: 352571072160421 Writing AT RIL... OK Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.29.5 after reset MSL still say ''Bypass MSL... error (2)" how can i solved this problem? |
The Following 3 Users Say Thank You to hippolyte85 For This Useful Post: |
10-19-2017, 23:04 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
The Following User Says Thank You to blang For This Useful Post: |
10-20-2017, 17:54 | #3 (permalink) |
Member: 361348 Status: Offline Thanks Meter: 635 | AFTER DOWNGRADE MODEM REV2 5.1.1 STILL NO OK BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-N9200 Software version: 29.5 Checking CERT file... OK KEY ID: 0092 Waiting ADB device... OK Reading phone info... Model: SM-N9200 Android version: 6.0.1 Product code: SM-N9200ZDUTGY Phone version: N9200ZCU2AOJ1 PDA version: N9200ZHU3CQD2 CSC version: CSC country code: CSC sales code: HW version: MP0.7ATGY Phone SN: R28H33ZNVNM Modem board: MDM9635M Security patch: 2017-04-01 RF cal date: 2016.03.29 IMEI: XXXXXXXXXXXXXXXXX Writing AT RIL... OK Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.29.5 |
The Following 2 Users Say Thank You to hippolyte85 For This Useful Post: |
10-20-2017, 22:46 | #4 (permalink) | |
If we will got phone with same problem in hands only then we can check and do something. | |
