10-26-2016, 13:05 | #1 (permalink) |
Freak Poster Join Date: Aug 2009
Member: 1092372 Status: Offline Thanks Meter: 32 | n9208 drk fix error Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair DRK Selected model: SM-N9208 Software version: 27.0 Checking local file... ok Searching server... ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM10 detected Setup connection... ok Reading data from phone... ok Sending data to phone... ok Sending data to phone... ok Waiting ADB device... ok Reading phone info... Recovery build version: 6.0.1 Boot version: N9208XXS3BPI7 Platform: exynos7420 Boot serial: 83f049565943594f Product board: zenlte Initialization zTool... ok Running zTool, please wait... Start... ok Initialization... ok Generate and check client proof... ok Verify proof by client... ok Checking DRK status... NG! Writing DRK... error (error(5.6.-14)) Done with Samsung Tool PRO v.27.0 |
